11-22-2010, 05:59 PM | #1 |
Newbie Join Date: Oct 2010 Location: Hemet
| BEC problem
I just installed a 6V./5A. BEC. im only getting 3 volts out of it, any ideas? I assume its just bad right? no internal adjustment? I dont want to open it up and void whatever warantee there may be.
11-22-2010, 06:01 PM | #2 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
What kind of BEC is it? If you've got a castle you need a link to ajust it. |
11-22-2010, 06:03 PM | #3 | |
11-22-2010, 06:10 PM | #4 |
Yep,I would say ya got a bad one but I havn't ever had one of those.Maybe someone else can chime in. |
11-22-2010, 07:46 PM | #5 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Have you verified that your input voltage is above 4.8 V ( 4 x 1.2V/Nicad cell). The specs for the BEC say that it will run on 4-19 cells. Narly1 |
11-22-2010, 09:02 PM | #6 | |
What if the input and output are backwards, would it hurt anything if I switched the leads? all 4 wires are the same color(2brown/2red). I put the jst end to the battery and the reciever end to the servo, and left the signal wire connected from the rx to the servo. | |
11-22-2010, 09:52 PM | #7 | |
BUT: Did you remember to pull the red wire that normally runs from the ESC to the receiver? Narly1 Last edited by Narly1; 11-22-2010 at 10:03 PM. | |
11-22-2010, 10:12 PM | #8 | |
I have the BEC out for testing so there is no load or resistance, I should be getting 6 volts out of it | |
11-22-2010, 10:20 PM | #9 | |
Narly1 | |
