11-24-2010, 09:13 PM | #1 |
Pebble Pounder Join Date: Apr 2010 Location: Tuscaloosa
| AX10 Motor Plate/Motor Mounting Problems
Hey guys, quick question for you all: Has anyone else had problems when mounting up motors onto the Axial black aluminum motor plate, in which the pinion gear end of the motor would not fit through the motor plate??? I'm building a "scale" crawler and when I installed an AX10 transmission and went to bolt up an old HPI 55t crawler king motor I had laying around, the pinion gear would fit through the hole in the motor plate, but the part on the motor that extends out and is supposed to fit through the motor plate does not. Is it just my case that this is happening with this HPI 55t motor or has it happened to other people? Thanks for the help in advance guys and have a great Thanksgiving. -Mike |
11-24-2010, 09:31 PM | #2 |
Rock Crawler Join Date: Oct 2009 Location: Michigan
The pinion gear won't fit through, or the bearing housing on the motor is too big and will not fit in the cut out of the motor plate?
11-24-2010, 09:37 PM | #3 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
a picture to show how much interfierance there is would be helpfull. but it cant be that much interfierance, fire up the dremel! even a file would have it done quick. |
11-24-2010, 09:39 PM | #4 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
I understand what your asking. Yes you need to use an adapter plate like what is used on the CR-01's or just get a motor with a flat face.
11-24-2010, 10:05 PM | #5 | |
RCC Addict Join Date: Mar 2010 Location: Yelm
11-24-2010, 10:09 PM | #6 |
On board now!! |
11-24-2010, 10:27 PM | #7 |
Yeah guys, the bearing housing will NOT FIT, but the pinion gear WILL FIT. Sorry for any confusion. SO THE BIG QUESTION: What motors could you guys suggest? I have an RC4WD Outcry ESC that can run down to a 30t motor. SO what motors have you all ran on the AX10 transmission/motor plate combo that fit nicely? (Only reason for using the HPI 55t was to get it moving/testing, as I want to run a 30 or 35t in the end.) |
11-24-2010, 10:40 PM | #8 |
Quarry Creeper Join Date: Nov 2010 Location: Toronto Canada
I have a brushless Goat motor that has a flat face on it but have also tried an Integy 75t matrix and some older motors (Orion Pilot and Kyosho) and they all fit so it must be just the particular mototr your using.
11-25-2010, 01:30 PM | #9 |
Newbie Join Date: Oct 2010 Location: Pennsylvania
