11-26-2010, 08:50 PM | #1 |
| linear mode on 3e
Anyone know how linear mode works on the 3e in relation to servo movement. Does it just move the servo position and stop in what ever position its at once the switch is released or does it return back to neutral? Is its only application in the crawler world the m2?
11-26-2010, 09:08 PM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
it is linear,,it applies signal linearly as you keep holding the button,,hold it down a short time it doesnt build any real speed,,hold it down for a bit and it builds speed as it goes along,,,,great for a winch. the servo/winch/whatever stops on command and returns on command
11-26-2010, 10:00 PM | #3 |
Now i'm not sure exactly how winch controllers work but i would think it would be similar to a esc so in neutral position it stops, but when you say both a servo and winch stops is kinda strange because for a servo to stop that means its got to have ch in the same position which seems like is possible with the linear switch but when a winch would stop that means it would return back to the neutral point. So unless winch controllers work differently than i think they should as well keep spinning at the speed once the button was released or a servo would have to return back to center once it was released. Please lmk if winch controllers work differently than i think. But i'm just trying to figure out what happens once the switch is released.
11-27-2010, 07:52 AM | #4 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
in linear if you bump the thumb up, it turns a servo slightly one way. if you bump it back down, it nutrals, if you bump it down again, it goes the other way. If you bump up, and hold, it will go to the max travel of the servo and stop, then you have to hold it down to get it to re-center. Kinda a PITA for rear steer, and really no point to a winch line. the linear mode almost reminds me of a push button trim. |
11-27-2010, 08:00 AM | #5 | |
