12-04-2010, 02:55 PM | #1 |
Rock Stacker Join Date: Oct 2009 Location: ky
| 4pk and dual fxr help
Well everything came in yesterday,did the harley setup for the 4pk, Well got the rig down and was doing just like should,then i guess i hit something on radio, now when i go to reverse they pull towards each other?? also when i lock the front or back, they will still roll some,is that normal?? dual fxr 4pk 45 handwounds xr10 |
12-04-2010, 08:31 PM | #2 |
It sounds like you reversed the throttle on the rear ESC. Yes, an electronic dig will still allow some motor roll when engaged... |
12-04-2010, 08:58 PM | #3 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
if you didnt accidentally revers that esc's channel make sure on the ch3 motor you have the dt all the way up to 100 going the same way as the ch2 throttle. In other words make sure you didnt dial it down into the negative side. Also with the fxr there is a setting that allows some anti roll. I think its like setting number 3 or 4 on the esc and i believe its called anti drag maybe? Read the manual and see what it say about it. I think you want it to be set to value of 1 for no anti roll. Just something to consider I dont know if thats your problem or not. |
