12-12-2010, 04:13 AM | #1 |
Rock Stacker Join Date: Nov 2010 Location: uk
| Savox Max Voltage ?
Hi guys Can anyone help me out ?.....im running a Savox 1256 through a CC BEC set @ 6volts but its not as strong as i would like. Does anyone know if these can take more voltage ?....only info i could find was the readings @ 4.8 and 6.0v Cheers MUD |
12-12-2010, 09:43 AM | #2 |
Quarry Creeper Join Date: Sep 2008 Location: Oakley
I ran this servo on my XR10 at 6v and didn't have any trouble with it, unless you got wedged down in a crack or something. Myself, I wouldn't try running it at more than 6. Savox has some new high voltage servos now that can handle 7.4v.
12-12-2010, 09:51 AM | #3 |
Newbie Join Date: Dec 2010 Location: IL
You could try and bump up the voltage if you want more power, but you must understand you run the risk of frying your servo... you can pay attention to the temps but there is no telling if/when the servo will grenade.
12-12-2010, 10:22 AM | #4 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
Servo's are rated at nominal voltage. What is the actual charged voltage on a 7.4v pack? 8.4v. What's the actual charged voltage on a .0v pack? 7.2-7.6v. Go ahead and bump it up to 6.8v. It's not as strong a servo as the Hitec 7955 or the Futaba 9157 but it's still a great servo. |
12-13-2010, 06:00 AM | #5 |
Thanks guys.....will up the voltage a bit and see what happens.....ive just bought a Hitec 7950 for it so it dont need to last long anyway |
12-13-2010, 06:05 AM | #6 |
Quarry Creeper Join Date: Jul 2010 Location: netherlands
let us know. I think you will shorten the lifespan of the servo when you bump up the volts a little bit |
12-13-2010, 01:14 PM | #7 | |
Quarry Creeper Join Date: Mar 2009 Location: Raleigh
I have a Savox 1268 and have been running 7.2 volts to it with no problem. My pack is a 7 cell 8.4 nimh pack, so I run a CC BEC. | |
