Thread: lipo conversion for Dx3r
Old 12-23-2010, 01:03 PM   #1
Default lipo conversion for Dx3r
Anyone do a lipo conversion for a dx3r? i'm tired of replacing those AA batteries
khwilliams is offline   Reply With Quote
Old 12-23-2010, 01:17 PM   #2
http://www.allerc.com/hyperion-lifepo4-2080-mah-6-6v-transmitter-pack-p-4724.html
plug and play as it gets
Rootar is offline   Reply With Quote
Old 12-23-2010, 04:52 PM   #3
i use duracell batt's and only replace them once a year....was thinking of getting nimh batt's and charge them on my hypi 060i .......bob
bob1961 is offline   Reply With Quote
Old 12-23-2010, 05:10 PM   #4
I looked into doing it but decided to just get some good rechargeables instead. I was doing some research and got 8 Eneloop batteries and a nice little charger for like $30.
SMR 510RR is offline   Reply With Quote
Old 12-27-2010, 03:37 PM   #5
I'd go LiFe if I knew that the radio could handle the voltage. Has anyone tried an unregulated LiFe battery in theirs?
I just picked up a DX3R with 3 SR3100 receivers for $75 for my trail rig so I don't have to take my 4PKS out into the woods and through stream and stuff.
Scottmisfits is offline   Reply With Quote
Old 12-28-2010, 01:24 PM   #6
No One has tried it?
Old 12-28-2010, 04:39 PM   #7
where did you pick up a DX3R and 3 rx's for $75??
Old 12-28-2010, 10:28 PM   #8
A local guy had it all up for sale.
No one has any answers for me?
Old 12-28-2010, 11:16 PM   #9
I would probably just regulate it down if you were going to do it...No reason to fry the radio.
Old 12-29-2010, 09:52 AM   #10
I've done it on my nomadio, was very easy, fitted a bec to control volts then used a 2s lipo, I just need to watch voltage but on the dx3r you can set you voltage alarm to warn you to charge
Hulksta is offline   Reply With Quote
Old 12-29-2010, 09:56 AM   #11
a little easier.....i use a traxxas style rx pack in mine.....5 cell nimh flat pack.....not as evil to the radio on voltage and lasts pretty long.....just pull the 4 cell box out....ad the end from a servo extension to the wireing of the 3r....you can even charge the pack through the charge port
flapjack is offline   Reply With Quote
Old 12-29-2010, 11:15 AM   #12
I think a 2 cell Life pack would be just about perfect. 6.6V and sized right.
AreCee is offline   Reply With Quote
Old 12-29-2010, 12:39 PM   #13
thanks for all the ideas guys, any pictures by chance?
Old 12-29-2010, 03:44 PM   #14
I read another Forum and Casey Peck from Losi/Spektrum/Horizon said he has been running a Lipo in his with no issue for a little over a year. I will be going with a Life pack once I add the receiver plug to it.
Thanks guys.
