12-30-2010, 08:13 AM | #1 |
| Rhino Battry Problem
Last spring I picked up three Zippy Rhino 610mah 20C 3 cell batteries. They were awsome in my Berg. I could run 2 courses safely on each battery and they had just enough punch. They probably have about 40-50 cycles on each one. About the same time I started running the XR-10, and around when the weather turned cold... all three batteries stopped taking any more than 400 mah on a charge. They can be warm, or cold... it doesn't matter. I am only getting around 400 on each one. Now if it only happened to one of them... I'd write it off as a bad battery. But all three at once? They have never puffed and they all balance fine. So... any ideas on why? Any suggestions on how to revive them? Thanks! |
12-30-2010, 08:25 AM | #2 |
40 to 50 cycles on each one, that is about the life cycle of a 20c cell being discharged in 10 to 15 minutes time. Sounds like you have used them up.
12-30-2010, 08:48 AM | #3 | |
Glad they were cheap Thanks ! | |
12-30-2010, 08:59 AM | #4 |
Quarry Creeper Join Date: Aug 2008 Location: 5280'
i have had some packs do that after i left them in the cold too long. i tryed to get them back but i never could. after that i have made sure that they stay warm!
12-30-2010, 01:22 PM | #5 |
Quarry Creeper Join Date: Jun 2005 Location: Las Vegas
Did you happen to store fully charged? storing fully charged will increase internal resistance and reduce capacity in short order. Some good info on storing batteries here: http://batteryuniversity.com/learn/a...ased_batteries I setteled on storing mine in my beer fridge... the chrispers are now good for something in that fridge These are nice and small, have good punch and best of all... ship FREE and are IN the US already http://www.hobbypartz.com/83p-800mah-3s1p-111-20c.html I'd like to try some of these... i just have to many batteries as is! http://www.hobbypartz.com/77p-sl800-3s1p-30c-3333.html Last edited by JSN; 12-30-2010 at 01:31 PM. Reason: added link |
12-30-2010, 01:30 PM | #6 | |
If I'm going with an 800mah battery I'm going for the 40C punch of the TP's or the Krawl Off-Road Batteries. Last edited by Harvo; 12-30-2010 at 01:33 PM. | |
