12-31-2010, 12:32 PM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: centereach
| Dx3e ??????
Does anyone use the DX3E. It was purchased for me for christmas. I was thinking of using it for my Micro Losi Crawler for the 4WS. I was going to do the independent steering. But now I here that the third channel doesnt return to the center. Its either one way or the other. No middle ground. Is this true.
12-31-2010, 12:36 PM | #2 |
Pebble Pounder Join Date: Jun 2010 Location: Ontario,Canada
Put the 3rd ch on 3 position and it will return to centre.
12-31-2010, 12:42 PM | #3 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
You will have to switch it back to center. It dosent self center.
12-31-2010, 01:08 PM | #4 |
12-31-2010, 01:08 PM | #5 |
12-31-2010, 01:52 PM | #6 |
| It should work, it is 3 positions. Your center position will be centered, left will be left, right will be right. Take the servo horn off and turn everything on. Now put the horn on, that is centered. Now hit the switch and go one direction and adjust your end point. Do that again for the other side. What you can do if you want is add a momentary 3p switch instead of the switch on the back. The spot on the back is a little hard to reach, on the side of the grip is much more comfortable. |
12-31-2010, 03:13 PM | #7 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
DX3E is a 3 position 3rd channel radio. Check your setup again.
12-31-2010, 03:55 PM | #8 |
Quarry Creeper Join Date: Jul 2008 Location: South Dakota
I'm pretty sure the instructions with mine said that if you switch it from 2pos to 3pos you have to rebind.
12-31-2010, 04:21 PM | #9 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
01-01-2011, 04:17 PM | #10 |
Rock Crawler Join Date: Dec 2005 Location: houston
01-01-2011, 07:27 PM | #11 |
