Thread: radio with 3 position switch
Old 12-31-2010, 10:05 AM   #1
Default radio with 3 position switch
Looking to get a 2.4 ghz radio with a true 3pos. switch with epa on that 3rd channel. One rig it would run a winch and the other rig it will run a vanquish dig. Do I even need epa for the winch? I'm assuming I do on the dig. Would like to get one one that doesn"t need to be modded. After seaching all over seems like maybe traxxas tq 2230 might be the way to go. Does traxxas still make this radio? If anything ever happens to the receiver down the road will another one be hard to get? Any other suggestions on a different radio that's under 150$
thanks
Steve
Steve p is offline   Reply With Quote
Old 12-31-2010, 10:30 AM   #2
Got Worms?
Dx3e
Traxxas doesn't make 3pos radios, so you would have to mod it or get a adapter from wantasummit
losikid is offline   Reply With Quote
Old 12-31-2010, 10:51 AM   #3
IMO you dont need epa's. I guess im old school rc guy but if you want to you can do all the adjustments with the servo linkages. its alittle harded than turning a knob but it works. For the winch you dont need the epa. EPA's are easier and if anything get out of ajustment you can fix it from the controler. As far as getting the controler, get what you need and want and dont forget to think ahead about what you might want to add. A forth ch. might be a good idea also. I think I would do a dx3e also..
buggynutt is offline   Reply With Quote
Old 12-31-2010, 02:04 PM   #4
Have you considered the Futaba 3PMX?
Maxx_Savage is offline   Reply With Quote
Old 12-31-2010, 05:27 PM   #5
The futaba is a little more than I wanted to spend. Plus I need to get anothe receiver for another truck.
Can Hitec servo's be used with the spektrum radio?
Old 12-31-2010, 05:42 PM   #6
Official Cook of the ECC
Scattman's Avatar
Yes, doesn't matter.
Scattman is offline   Reply With Quote
Old 01-01-2011, 06:04 AM   #7
ok thanks guys I will be ordering the DX3E today
