01-02-2011, 09:38 AM | #1 |
Newbie Join Date: Jan 2011 Location: Traverse City
| 4S setup
After this last brushed motor wears out I would like to move to a 4S setup, after doing some searching I haven't seen any ESCs with a 4S rating. Can somebody recommend a 4S ESC and motor combo. Thanks Jason |
01-02-2011, 09:55 AM | #2 |
Rock Crawler Join Date: Oct 2007 Location: Grants Pass
| I'm currently running a fxr with a different cap on 4s. works very well . Dont try with the stock cap. Also have a castle sidewinder running on 4s with no mods other than external bec
01-02-2011, 09:56 AM | #3 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
Mamba max pro and Holmes brxl both will run on 4 cell |
01-02-2011, 10:39 AM | #4 |
01-02-2011, 12:04 PM | #5 |
I didn't think to consider castle, and that is my preferred ESC for helis. I will have to check out the brxl motors, are there other manufactures that produce a 4S motor seems like there would be quite a few in a 540-550 size. Im currently running a novak BEC. Thanks for the info Jason |
01-02-2011, 12:07 PM | #6 |
Quarry Creeper Join Date: Dec 2008 Location: other side of the track,the bad side
I run a mamba max on 4s with 2 jp 35t handwounds in my moalosi |
01-02-2011, 12:13 PM | #7 |
| Mr. Glassman Is the linked motor the one you referring to? Looks interesting and I'm a fan of outrunners. http://holmeshobbies.com/product.php...&cat=19&page=1 Jason |
01-02-2011, 12:34 PM | #8 | |
Jason | |
01-02-2011, 02:42 PM | #9 |
Rock Stacker Join Date: Apr 2010 Location: Portland/Vancouver
| With a Losi, it's enough of a disadvantage to not spend the money on it for sure. Almost un-drivable due to the low speed cogging.
01-02-2011, 04:44 PM | #10 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
I run a novak ballistic 21.5 on 4S, it works great! Escpecially with the HD worms released now, your going to want a little bit slower of a motor than the 17.5 most guys are going with.
01-02-2011, 05:38 PM | #11 | |
01-02-2011, 05:54 PM | #12 | |
What ESC are you using? Thanks Jason *Edit* I like the pricepoint of non-sensored systems, but I don't want to deal with trying to tune-out annoying cogging. Last edited by jason46; 01-02-2011 at 06:05 PM. | |
01-02-2011, 07:26 PM | #13 | |
I'm running a mamba max pro. I shortened the wires on the circuit board, waterproofed it and took the fan off The slow speed control and glitchyness of a non-sensored system is going to bug you when competing. Spend the extra $50-$100 the first time, so then you don't have to buy twice. That's my recommendation. TOM | |
01-03-2011, 10:50 AM | #14 |
Quarry Creeper Join Date: Jan 2010 Location: Albuquerque
Think of your ESC as a funnel...it won't let anymore juice pass than a 2S will give...if you use a 3S or 4S, the ESC will store the extra juice as HEAT...so it's pointless to use more than you need (and expensive)
01-03-2011, 11:07 AM | #15 |
Newbie Join Date: Dec 2010 Location: Gilbert
Are you saying an ESC will output the same "juice" no matter if its a 2S or a 4S battery? So you're not going to notice a difference between using a 2S or a 3S battery? I beg to differ on that. An ESC controls the amount of "juice" its pulling from the battery and sending to the motor. An ESC is definitely not a funnel. An ESC will let more juice than a 2S to pass through it. Or maybe you're referring to your own ESC.....? |
01-03-2011, 02:03 PM | #16 |
More voltage on tap, by running a 4S battery instead of a 2S battery, will give you more rpm out of your motor and smoother power delivery down at low rpms. HEAT is created by a load, in our case its caused from the motor. The more load you put on the motor, the more heat you will create. If you keep a light load on your motor and up the voltage, heat is not increased. That's my experience with ESC's and motors. I don't do it for a living, nor am I a scientist or engineer. That's just my 2 cents. TOM |
01-03-2011, 04:03 PM | #17 |
| facts:
The cornerstone feature of an ESC is the fact that it's a resistor (V = IR)...all the other features are built on that.. voltages over 7.2 are stored as heat since 1/10 ESC's are designed only to allow 7.2V to pass (to protect 1/10 motors). All you need is a high quality 2S with a high discharge rate (A) for high performance crawling...and that's all you need. This will help you understand the basic function of an ESC: http://en.wikipedia.org/wiki/Resistor |
01-03-2011, 04:28 PM | #18 | ||
01-03-2011, 04:28 PM | #19 | |
Rock Crawler Join Date: Apr 2005 Location: Monroe, Louisiana
What makes the motor turn more rpm's with 3s than 2s? Quote:
01-03-2011, 05:10 PM | #20 |
The job of an esc is not to funnel power, but to proportion the amount of voltage going to the motor from 0% up to 100%. From 0v to 14.4v, or what have you... But you seem too smart to know that.
