01-03-2011, 01:47 PM | #1 |
Newbie Join Date: Sep 2010 Location: Detroit
| lipo storage?
quick qestion for ya'll i know nothing about lipos really, im about to pick up some 5000mah 25c 2s lipos, now i dont run my trucks every day, i'd say maybe a few times a month. now if i fully charge a lipo and put it away, how long untill the voltage will drop to a level where the cells are damaged? |
01-03-2011, 01:52 PM | #2 | |
I wanna be Dave Join Date: Oct 2006 Location: Centered
If your charger has a storage charge rate, use it, otherwise store them at around 65% If they sit idle for any prolonged periods of time make sure you check the voltage every once in a while. | |
01-03-2011, 02:09 PM | #3 |
Pebble Pounder Join Date: Dec 2010 Location: St. Lawrence County NY
I had 5 - 1320 mAh lipos that I used with a RC helicopter, I put them away back in 2006 with about a 70% charge. I recently bought a crawler, just before Christmas, and was going to order some batteries when I remembered the 5 that I had put away. All 5 of them had about the same voltage, took a charge and have been working fine since. I was shocked and extremely happy that I didn't need to buy new batteries.
01-03-2011, 04:00 PM | #4 | |
so basically it takes along time for the cells to lose voltage? | |
01-03-2011, 05:26 PM | #5 |
Rock Stacker Join Date: Dec 2010 Location: USA, OH, Columbus
I think it depends. They don't self-discharge like nimh batteries will, but I have had some go completely dead while in storage. So ideally you should check them every now and then as suggested, because once they lose their charge you will probably not be able to revive them- I never have. Storage voltage is definitely best. My Hyperion charger has a storage charge setting that I use if I won't be running the battery for a few days or more.
01-03-2011, 06:12 PM | #6 | |
alright cool, im going to have to look and see if my ICE charger has a storage charge | |
01-03-2011, 06:40 PM | #7 |
RCC Addict Join Date: Oct 2006 Location: crawlifornia
the ICE does not have a storage charge. I would recommend getting a balancer also so you keep them tip top. I've had batteries go out of balance in storage
01-04-2011, 09:09 AM | #8 |
Newbie Join Date: Dec 2010 Location: Jacksonville
| storage
Store them in an old ammo can or some other non flammable container!
