01-08-2011, 12:26 PM | #1 |
Rock Crawler Join Date: Feb 2010 Location: Sturgis
| topped off voltage vs mah
Simple example I run my lipo for 20 min and lose a few volts , so I throw it on the charger (imax b6pro) and it balance out both cells to 4.2 but only puts 150 mah into the battery . Now is that all it needed to get back to the 1800 mah rating or should I be waiting for the charger to put more mah back in ? Thanks in adance - Bob p.s. Im not waiting for the charger to say done because it will toggle between 4.20 on one and 4.19 on the other cell for like 15 min . |
01-08-2011, 02:37 PM | #2 |
Rock Stacker Join Date: Sep 2010 Location: australia
150 mah is all you used. The charger can only put in what you used. then the battery is full
01-08-2011, 03:12 PM | #3 |
duringthat 15min or so the cells are jumping around 4.20 and 4.19v before it says done the charger can put some more mah into the battery. for instance on my losi micro crawler i have a 250mah lipo for it and after running to cutoff and charge it, when it's cells are jumping around at the 4.19-4.20v area it still adds another 25 or so mah to the battery.
01-08-2011, 03:33 PM | #4 |
cool thanks
