01-11-2011, 11:57 PM | #1 |
RCC Addict Join Date: May 2010 Location: Los Altos, California
| Power cutting off PLEASE HELP!
hey guys, so in my XR-10, i have a slight issue.. when i reengage 4wd, from front or Rear dig, the RX system cuts-off for amoment and then comes back to life under the control of the TX.. whats the issue?? PLEASE HELP! im running: Novak m2 dig ESC DX3R+SR300 RX 7950th servo, set at 6.0V with Castle BEC |
01-12-2011, 05:45 AM | #2 |
I would check all electrical connections, starting from the battery. I had a similar issue caused by a bad power connection, things would work fine, then dead.... With power on, twist/pull connections and see if the RX stays on. |
01-12-2011, 07:31 AM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Sounds like it may be over drawing at the moment you re-engage the second motor which is causing your Rx to cut out. Besides checking all your connections you could also try raising the BEC voltage...both the servo and Rx are more than capable of handling a higher input. |
01-12-2011, 07:39 AM | #4 | |
Well I think I'm going to be switching to deans instead of traxxas. Traxxas plugs may bounce out of contact, cutting off.. | |
01-12-2011, 07:41 AM | #5 | |
Btw would adding a capacitor help alittle? Smooth out the flow more? | |
01-12-2011, 08:23 AM | #6 | |
Also make sure no wires are under tension when the chassis flexes. A few others on this forum have had plugs getting pulled when the suspension moved causing intermittants in electrics operation. | |
01-12-2011, 01:09 PM | #7 |
| I am running the same thing as you are, my CC BEC is set to 6.5v. That provides plenty of power to the RX and servo w/o over stressing it if it gets bound up. Other than glitching caused by the M2 under firmware 1.0, I have not had any of the problems you are describing. Are you running 2S or 3S?
01-12-2011, 05:10 PM | #8 | |
all my plugs into the RX have free movement. so that takes away from that. | |
01-12-2011, 05:11 PM | #9 | |
hmm maybe im using the older firmware, but does the older cause the M2 to cut-off power, and then come back? ill try running 6.5v. im running 2s. | |
01-12-2011, 05:18 PM | #10 | |
A poor fitting connection can break the flow of power when moved a bit, "loose" connections are usually NOT good. | |
01-12-2011, 05:21 PM | #11 | |
Yea, this is my reason for switching to Deans now. easier to solder. | |
01-12-2011, 06:19 PM | #12 |
Gunna ask a dumb question here, but.... Did you remove the red wires from both leads going from the M2 to the RX? |
01-12-2011, 07:12 PM | #13 |
01-12-2011, 08:57 PM | #14 | |
All your plugs are mechanical connections, they MUST fit snug to pass full voltage/current and have no intermittants. | |
01-12-2011, 09:01 PM | #15 | |
yea, i just ran with the deans! im not seeing any issues! screw traxxas plugs, their POS! oh, but new issue, it now only happens when the battery is close to LVC, and also, it seems to be that the Rear still has issues. the front have no issues now, until LVC | |
01-13-2011, 10:55 PM | #16 |
So I did everything in my reach, soldered on deans and set the bec to 6.5v. Once I swithed to deans the issue got better, but was still there, so I upped my bec to 6.5v and there is no change from adding deans. |
01-14-2011, 05:51 PM | #17 |
Rock Stacker Join Date: Nov 2010 Location: SE PA
just a thought but if the dig is moved by a servo check your servo . my 3 day old scx10 started shutting down when i was steering! new servo put a stop to it |
01-14-2011, 07:36 PM | #18 | |
but thanks for the in put | |
