Thread: Mamba Max Pro 1 Cell
Old 01-18-2011, 09:29 PM   #1
Default Mamba Max Pro 1 Cell
Just looking at a new speedo for my crawler and i was looking at the Mamba Max Pro 1 Cell and was wondering if it would work with my Ballistic 18.5?
In other words im asking if Castle and Novak are buddies?
-Brady
bmangdog is offline   Reply With Quote
Old 01-18-2011, 10:00 PM   #2
It'll work just fine As far as I know, every major brand of esc/motor is built to use the same standard sensor wires so you can use any esc with any motor.
Almighty Malach is offline   Reply With Quote
Old 01-18-2011, 10:06 PM   #3
20K Club
Harley's Avatar
Location: Sending illegals home one Hayabusa at a time.
Isn't the 1 cell for onroad racing?
Harley is offline   Reply With Quote
Old 01-18-2011, 10:08 PM   #4
Are you aware that it is specifically designed to be used with a 1 cell lipo battery? You're crawler would be really slow on 3.7 volts.
kwkride is offline   Reply With Quote
Old 01-18-2011, 10:08 PM   #5
I believe the only difference is that there is no BEC in it. They were making them to use the voltage boosters or the little Lipo or Life receiver packs to power the receiver. If you want to use it in a crawler you NEED to use a bec. I know we tried one with a bec and it's didn't work.
http://www.castlecreations.com/produ...o-onecell.html
Scottmisfits is offline   Reply With Quote
Old 01-18-2011, 10:17 PM   #6
Seems it does everything the reg. one does, just doesn't have a BEC or fan so it's smaller and lighter.
The only compatability issue's are with Novak Goat ESC's, everything else can mix and match. Stupid Novak makes you use thier crawler motors, nothing else will work. We run a 18.5 ballistic on 6s with a MMP in a LNC with no issue's.
indiana mudcat is offline   Reply With Quote
Old 01-18-2011, 10:30 PM   #7
Great to hear thanks guys
Im choosing the 1 cell because its smaller, lighter and doesnt have an internal BEC. so theres one less thing to deal with. the 1 cell will still run 1-6s lipo.
Old 01-18-2011, 10:47 PM   #8
What does the motor temp at after a comp run on 6s?
highlandcrawler is offline   Reply With Quote
Old 01-19-2011, 08:47 AM   #9
I run a MMP one cell edition in my shafty, they were created to compete in one cell class on road races. Theyvcan handle 1-6 cell lipos, they don't have an internal BEC, so you should and must use an external one. As far as being smaller and lighter, I would say its pretty large compared to most others especially something like an FXR. I chose the MMP one cell because I got it new in box on craigslist for $40, then I figured out what it was capable of. Most of its potential is unused, but the ability to run brushed/brushless/sensored/unsensored/6 cell is a nice feature. You never know when you might want to make a 24 volt 8000kv mini t.
day215 is offline   Reply With Quote
Old 01-19-2011, 09:16 AM   #10
Maybe 120, it's cool enough that I've never bothered to get my temp gun out to check it. Volt up, Gear down.
Old 01-19-2011, 04:05 PM   #11
Puller on 4s with 13t
Old 01-19-2011, 04:08 PM   #12
Crawlers need an external bec anyway regardless of esc and the lack of the fan make it way smaller and lighter than the other option of a regular pro. I think castle is loosing sales on these due to labeling. If you think about it its just as good for crawling as it is for onroad
Old 01-19-2011, 04:38 PM   #13
I can just imagine that.......
JustinThyme is offline   Reply With Quote
Old 01-19-2011, 04:46 PM   #14
Thats why i want the 1 cell, because it doesn't have an internal bec. Should I run a fan with it?
Old 01-21-2011, 05:43 PM   #15
Ttt
Old 01-22-2011, 08:40 PM   #16
Doubt you will need a fan...
FRENCHBLUE72 is offline   Reply With Quote
Old 03-31-2011, 07:22 PM   #17
I need some help calibrating my MMP 1 cell with my DX3r...I see my 1cell does not have an on off switch. How do you calibrate without it? I see the switch mentioned in the .pdf instructions per castle.
drusierdmd is offline   Reply With Quote
Old 03-31-2011, 07:36 PM   #18
Just plug the battery in while starting the calibration.
You eventually pic up the knack of plugging a battery in one handed.
If you cant do it one handed, just get a 2nd set of hands for 10sec.
WIDELOAD is offline   Reply With Quote
Old 03-31-2011, 08:40 PM   #19
mission accomplished...just wish castle would update their documentation to reflect this. I opened the MMP case an spent an hour or two trying to figure this out...one last question, I reattached the red lead on the receiver lead, is this correct? The wiring diagrams I saw had this removed.
Old 04-01-2011, 07:05 AM   #20
Yes, there is no need to have any of the wires from the ESC plug pulled when running the MMP1C....even with an external BEC installed.
JeremyH is offline   Reply With Quote
