01-20-2011, 08:02 AM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: Goin broke losing weight.....
| BEC programming issues
Has anyone had trouble programming bec's using vista or 7? I can program esc's just fine. I am running as adm also. Thx
01-20-2011, 08:12 AM | #2 |
Rock Crawler Join Date: Aug 2010 Location: Socal
No problems with windows 7. Is it a software problem or are you not getting the green light on the connector. I was having trouble the other day getting the green light when I hooked it up. Realized that by deleting the on/off switch off my ESC, the BEC was sending power to the Speed controller everytime I hooked it to the computer.
01-20-2011, 08:14 AM | #3 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
I havent had any issues using Vista. I did have an issue with one of my USB ports not liking the castlelink, but I just used a different one and everything was fine.
01-20-2011, 08:25 AM | #4 |
Look on the CC website, it give special instructions on how to use the castlelink program if you have vista and or 7. I was also having a problem getting it on my computer, then I read the instructions and all good. John |
01-20-2011, 09:03 AM | #5 |
RCC Addict Join Date: Aug 2009 Location: Earth?
If the castle program willnot recognize the BEC you MUST disconnect the power wires on the BEC from the ESC. De-solder, unplug, or cut, whatever the case may be. If you get a error when trying to open the castle program with version 3.27 or 3.29 reload version 3.253 and it should work again. I cant get 3.27 or 3.29 to work with Vista, but I seem to be the only one so far.
01-20-2011, 09:21 AM | #6 |
It doesnt work either connected to esc or by itself. The only one i have that will program is toast. I run it exactly like cc says to. The green light on bec is on when connected, but it says its not connected on pc. I dont think usb port is bad because it will program an esc normally. I have also programmed them at a buddys on his pc using vista while wired in w no probs Thx for replys |
01-20-2011, 09:35 AM | #7 |
If it's wired to an ESC you need to plug a battery in.
