01-23-2011, 04:15 PM | #1 |
Quarry Creeper Join Date: Jan 2011 Location: Hurricane
| which motor should I go with?
I have a SCX10 with a Novak Rooster Crawer and a 55T motor, I installed a 25T pinion and lost the torq so I installed a 21T. I still don't have the wheel speed that I want. Can anyone tell me which motor I should go to, to get a good amount of wheel speed but also have a good amount of torq? Thank you for all your help.
01-23-2011, 04:21 PM | #2 |
Newbie Join Date: Apr 2008 Location: The Burg
If you are running lipos step up to 3s on the 55t with the original gearing. Watch your motor and esc temps, adjust gearing to suit the temps. Many people are running the rooster on 3s and they seem to be handling it just fine. Remember... "volt up and gear down".
01-23-2011, 04:29 PM | #3 | |
01-23-2011, 05:30 PM | #4 | |
You may just want to try a 35t. | |
01-23-2011, 05:38 PM | #5 |
I wanna be Dave Join Date: Jan 2008 Location: GrandRapids, MILITIAGAN
No go on 3s lipo. I have seen my rooster goup in flames when I WENT TO 2S LIPO I dont know why it did it. Worked fine before, then one day. Poof in flames.
01-23-2011, 05:47 PM | #6 |
| If I go with a 35T why I lose ant torq? I thought the higher the number the better the torq but I see people talking about using low number motors for their TTC. I am kinda confused on the motor ratings.
01-23-2011, 05:50 PM | #7 |
| Depends, if you get a good handwound. I got 35t handwound motors and they spool up and lay down some mad torque.
01-23-2011, 05:57 PM | #8 |
01-23-2011, 05:59 PM | #9 |
The higher the turns the more torque the lower the number the higher the rpm. if you run a smaller pinion or a larger spur you would be gaining torque so that the use of a lower turn motor (higher rpm) would be practicle. The higher torque motors are great for off the line speed or just crawling along. the lower turn motors (higher rpm) combined with the lower gears allow the motor to spin more and maintain the low speed torque while giving you the option of having more wheel speed at WOT.
