01-24-2011, 10:46 AM | #1 |
Newbie Join Date: Jan 2011 Location: Manassas
| Nomadio React Programing help
Hello all, new to the hobby. I actually do the real thing and decided to do it on a RC scale as well after seeing a few on a run. I played with one and now i am hooked. Anyways below are some basic specs. i want to program the React to beable to do reer steer and the like. Also Do i need anything special to do a dig? Any help with the programming would greatly be appreciated. Thanks in advance for your time.. FUTABA S9402 SERVOS ONE FRONT AND REAR ( 4WS ) AXIAL AX24007 MOTOR TEKIN ESC FXR NOMADIO REACT RADIO 2.4 GHZ RADIO AND RECEIVER |
01-24-2011, 11:30 AM | #2 |
Here are the settings from my React on my dual ESC front and rear steer super: I use the thumb wheel for the rear steer and have it indexed for 5 positions on each side (and one in the center) and have the rear servo plugged into channel 4. I use the grip soft key for rear dig. I hope this is helpful. |
01-24-2011, 11:47 AM | #3 |
can i do this with only one esc? I dont need anything else for it to beable to dig? this helps alot thank you |
01-24-2011, 11:51 AM | #4 |
What truck are you running?
01-24-2011, 11:55 AM | #5 |
Axial 10, AX90004 ARTR KIT to be exact.. |
01-24-2011, 11:59 AM | #6 |
Ahh....ok....for a shaft driven crawler, you'll need either a driveshaft disconnect type dig (Billet Works Designs "U-dig"), or a transmission disconnect type dig (Eritex or Vanquish).
