01-26-2011, 11:01 AM | #1 |
Rock Crawler Join Date: Jun 2010 Location: SENECA
| Dual Mamba Micro Programming
I've pretty much got both of them programmed the way I want them for now. My question is, does anybody play with there throttle curves?
01-26-2011, 11:07 AM | #2 |
Rock Crawler Join Date: Feb 2009 Location: Chandler, AZ
01-26-2011, 11:10 AM | #3 |
Gold Star Baby! Join Date: Feb 2009 Location: Arizona
I have...you must be proficient with the throttle curve settings.. it takes alot of time to get it where you like it..I did alot of tweaking when I was running one..then two I made less ajustments..but I also knew what I preferred for throttle responce.. I would adjust a throttle curve then save it and copy it to the other esc good luck |
01-26-2011, 11:11 AM | #4 |
01-26-2011, 11:13 AM | #5 |
01-26-2011, 11:15 AM | #6 |
It's really not worth it. I did mess with mine. I was trying to get just a little more low end control, but it took a long time and a lot of hooking and unhooking them from the Rx in order to get any noticeable change. From what I've seen these curves are generally more useful in racing and such. But if you do...definitely do what they're saying about copying and then loading it to the other ESC. |
01-26-2011, 11:17 AM | #7 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I have mine adjusted some, I have always run mine that way. Like John said, you could do it with the radio. When I first adjusted mine it was because my TX did not have expo adjustments. All my TX's now have expo adjustment but I still just run the curves on the ESC's. |
01-26-2011, 12:03 PM | #8 |
If I do it with the radio I'll have to read since its the new 4PL.
