02-01-2011, 08:49 PM | #1 |
Gold Star Baby! Join Date: Feb 2009 Location: Arizona
| Castle 25 ESC problems
So I put the 25 esc in the mini so I can use the Mamb micro for my daughters rig...no issues with the M-mini..So i wire it with the BEC powering the servo with the signal wire in the receiver only and leave the 3 wires from the ESC to the receiver...using a 4pks when I apply throttle it makes the steering wiggle back and forth..So i try a brand new servo with the ESC powering up the servo ,no BEC and when I pull the throttle its ok but when I steer it , it will go forwards and backwards with out touching the throttle.. So Im wondering do I need some sort of capacitor on the motor ? BTW it is a CrawlerMafia 16 turn motor.. Now let me recap..with the Mamba micro there were no issues with the BEC powering the servo and the esc powering the receiver...my guess is it is the motor that needs a capacitor or the speed control is NO GOOD.. any help would be GREAT..tomorrow I will be calling Castle Cust serv |
02-01-2011, 08:52 PM | #2 | |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
02-01-2011, 08:58 PM | #3 |
yup and let me clarify..it will not steer back and forth as much after the initial pull of the throttle..so it is not in brushed mode..but thx..firmware has been updated to 1.29 beta..thats what it says..thats all the same firmware I have all my other Mamba micros updated too. |
02-01-2011, 09:07 PM | #4 |
I have a similar setup in my super-light 2.2 Scaler. Mamba Micro 25 Castle BEC Spektrum AR6000 RX Bluebird 200oz Servo 3 Cell Lipo I have it wired in what appears to be the same fashion as you described.....and I cannot recreate the issue. My motor is the only obvious difference....I run a brushless outrunner. I am sorry that I am not of more help. I did try to recreate the problem...without success. Sounds like it is time to call Castle tomorrow. (IF they are open for business tomorrow after the blizzard that is pounding the Midwest right now.) |
02-01-2011, 09:11 PM | #5 | |
thanks for your HELP..what Im doing now is going to try it with a specktrum receiver and radio and see what happens...stay posted...I will report in 5 minutes Quote:
02-01-2011, 09:15 PM | #6 |
Well its not the radio...tried the spektrum with Dx3r and EXACT same thing,so I imagine that this rules out the radio gear..so with Futaba and Spektrum same result...Hmmmmm..hope castl answers their phone!!
02-02-2011, 07:21 AM | #7 | |||
RCC Addict Join Date: Dec 2007 Location: Chuck Chuck Chuckin Rocks.
You stated that it's not in brushed mode???? Isn't it a brushed motor???? JC | |||
02-02-2011, 07:38 AM | #8 |
02-02-2011, 08:04 AM | #9 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
Try two things try version 1.28 firm beta and then pull the power wire on the 25 and power the reciever off of the BEC. I have never had to run caps with my holmes motors in 25's
02-02-2011, 08:09 AM | #10 |
Well, first, needs to make sure that the esc is set for brushed mode...... JC |
02-02-2011, 10:58 AM | #11 |
02-02-2011, 11:36 AM | #12 |
One last item to look at also is to make sure you use the black and red esc connections now. Not the white anymore. Brushed motors use caps to filter noise during operation. You can run without also. May want to double-check everything again, or try that esc with the steering disconnected. JC |
02-02-2011, 11:47 AM | #13 | |
Thanks for all your help...but after ALL diagnosis I have determined that either the ESC has a problem or I need to add capacitors to the motor..I will keep this post INFORMED as I get more info..now to call Castle | |
02-02-2011, 11:58 AM | #14 |
I only run my signal from the servo to the rx and it works fine, on someone else's rig I had to connect the negative also or it acted funny.
02-02-2011, 12:02 PM | #15 |
Rock Crawler Join Date: Feb 2008 Location: Nebraska
I was running in to the same issues on my mini crawler Mamba 25 Orion Baja motor 3s lipo Hitec 645MG servo Spektrum SR300 receiver I had the ESC powering the receiver and the BEC powering the servo. When I pulled the throttle (even slowly) the steering would jerk to the right and then straighten out. It was very flaky. I also tried having the BEC just plugged in to the receiver (with the power wire pulled from the ESC plug) so that it could power everything. This was stable, but the servo seemed to be lacking power. It was very slow and weak. After trying several things including switching servos, here is what I ended up with. The BEC is wired to the servo for power and plugged in to the receiver to power it. I removed the red wire from the ESC plug, so that it is not powering the receiver. It is all stable and working very well now. |
02-02-2011, 12:10 PM | #16 |
RCC Addict Join Date: Jan 2010 Location: Dallas
I just recently helped a guy set up a 25 as the initial firm ware did not allow for brushed. Would it be worth connecting it to castle link and going back to the default settings then resetting everything again to make sure it all resets right? Also I am going to ask a very stupid question but did you rebind for failsafes and recalculate? You said you are running spektrum right?
