02-09-2011, 08:39 PM | #1 |
Quarry Creeper Join Date: Jan 2009 Location: atlanta
| mamba max wont beep
will a mamba max beep when set for brushed motor?Cant calibrate it to a dx6i tx and a6200 rx also does it have to be in throttle channel, will be running 2 mambas.I want to run front esc off right stick and rear esc off left stick.thanks
02-09-2011, 08:43 PM | #2 |
Here are the settings I used to use when I had a dual ESC setup on my DX6: Ch.1 - Throttle - left stick vertical movement (front throttle) Ch.2 - Aileron - right stick horizontal movement (rear steering) Ch.3 - Elevator - right stick vertical movement (rear throttle) Ch.4 - Rudder - left stick horizontal movement (front steering) As for the ESC beep....it is possible to turn that off when hooked up to the Castle Link....maybe that opting is off. Have you connected it to the computer to see? |
02-09-2011, 08:56 PM | #3 |
Have checked setting on esc,if i have removed the on off switch from esc wiil that be a problem.Also when i ran one tekin rebel on same super i run esc from elevator channel.would like to do the same and run rear orr rudder will that work?
02-09-2011, 10:48 PM | #4 | |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
JeremyH no you cannot disable the beep. | |
02-09-2011, 11:11 PM | #5 |
Got it to calibrate and beeps are very low and some one listen for the beep,now i will try to get it to work on right stick,I have used right stick before changing to dual esc.I liked it right stick better.So just plug in to another channel and recalibrate,been trying now wont calibrate in elevator.thanks for your help guys,will let you know tomorrow if it works.
02-10-2011, 08:05 AM | #6 |
Wheelstoo, yes you can remove the switch....all of my castle ESCs have this switch removed and I have not had any issues. Just solder the two leads together and put some shrink over them. Remember, you'll need to disconnect your battery to turn the truck off. Oops....sorry....yes, for some reason, I thought he was asking about the "on warning" beep.... Last edited by JeremyH; 02-10-2011 at 08:09 AM. |
