02-12-2011, 09:05 AM | #1 |
Quarry Creeper Join Date: Jun 2010 Location: Elk Grove
| Dual CC BEC's??????? Can it be done?
Here's the situation, I run a Mamba Max Pro special edition without a built in BEC. I use a single CC BEC set to 6v to power my RX and servo. I'm getting ready to pick up a Whitecaps HS-7950, I would like to power it with a little more than 6v, but my RX is only rated to 6v. I wanted to run another BEC set to 7-7.4v directly to the servo and keep the other BEC running to the RX. I have been told by castle's tech support that it can't be done, the two BEC's will conflict with one another. Does any one have any suggestions on how I could work this out? I thought about running a 2s pack unregulated directly to the servo, my rig weighs in at 6.24lbs so I'm not real keen on taking on the extra weight. Thanks for any suggestions you guts can provide, its appreciated |
02-12-2011, 09:12 AM | #2 |
cherry bomb Join Date: Jul 2006 Location: Nanaimo, BC, Canada
if they were both plugging into the reciever they would conflict, since they are powering sepperate devices, I see no issue.
02-12-2011, 10:09 AM | #3 |
That's what I was thinking, but tech support mentioned something about them having acommon ground that would create an issue.
