02-14-2011, 09:37 PM | #1 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
| Scaler servo help needed..ASAP
I have two Hitec 7950th servos for my class 3 scaler build. One is new and one is out of my 2.2 comp rig after about 3 comps on it. So I set out adding waterproofing to the oringed servos as everyone says they need more than the orings provide, and these babys are too expensive to toast.....so I carefully disassembled them to coat the boards in silicone, and filling the cavity next to the motor. I reassembled them while resetting the o rings, and let them dry.....To find them both locked up. So disassembly showed silicone had got around the motor pinion, and in the lower gear.. I cleaned them out and see the one gear that is driven by the pinion appears to be chipped, and the other was fine.....I put them together....the one with the questionable gear runs fine quickly....but twitches if moved slowly......the other spins to one side and locks solid regardless of wheel position.....So I'm feeling really disgusted in feeling that I trashed $250 of servos.........What I was attempting to prevent.....so where should I go? Two more servos like them, and use these for parts???? Traxxas waterproof servos????? |
02-15-2011, 12:57 AM | #2 | |
Pebble Pounder Join Date: Jan 2010 Location: Joliet
02-15-2011, 04:25 AM | #3 |
I wanna be Dave Join Date: Nov 2005 Location: Here
Second that one. I would have packed the cases with DiElectric Grease and dipped them in tool dip, add an O'ring and it is water resistant. I wouldn't have used those servos, there are less expensive, high torque servos out there that wouldn't hit the pocket book as bad if ruined. 486oz is overkill for a scaler. |
02-15-2011, 04:41 AM | #4 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
I found this out the hard way myself by using marine (waterproof) green grease. The stuff is great and is all I run, but a little goes a long way. Too much and your steering starts to look like a little old lady is behind the wheel (i.e. slow and un-reactive). Double check your bottom pin is in the right position on the one that locks to one side. I agree, kind of expensive servos to tinker with. I do run a 400 oz/in on my scaler, and it helps out in the comps a lot. These scalers are heavy and need a lot of torque to get the wheels pointing the right way! Wes |
02-15-2011, 08:15 AM | #5 |
So what does everyone use for scaler servos? The traxxas 2075 puts out 125 oz of torque, which is really weak. Is there any better options?????
02-15-2011, 09:47 AM | #6 |
RCC Addict Join Date: Nov 2009 Location: New Wilmington, PA
5645 2 of them, and I keep a spare set of gears. I chipped a tooth off of one this past weekend. If those are junk, send them my way, and I'll work till my fingers bleed trying to get them going again. |
02-15-2011, 10:17 AM | #7 |
02-15-2011, 10:33 AM | #8 |
