02-20-2011, 12:17 AM | #1 |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
| B1r problem
hey i just received a b1r in a trade i can not get it to turn the motor. when you turn it on it has a really really quiet start up chime and after programing the end points for my radio it will not send power to the motor. the led's light up with the trigger pull like everything is working but its not please help me out if you can. this is the first tekin esc i have ran so im not sure what i can try to fix it
02-20-2011, 08:35 AM | #2 |
I'm assuming you know the motor is good? If so, did you try to spin the motor by hand while giving it throttle? |
02-20-2011, 09:20 AM | #3 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
What radio are you using? Do the lights on the esc ramp up when you pull the trigger? or are there a set of three lights that are blinking? Try powering the esc and set the parameters using the leds. Then re-sync the radio to the esc.
