11-22-2004, 06:55 PM | #1 |
Pebble Pounder Join Date: Apr 2004
| motor cleaning
i know this has probably been covered but after using search i cant find how to clean and make (fairly)good again a stock clod motor. all i can remember is that you run it under water
11-22-2004, 06:58 PM | #2 |
I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Re: motor cleaning
Plug it into a battery and shove it into a sinkful of water, hold it there till it stops blowing crap, if it blows out a ton of crap, empty the sink and do it again till its clean. Run it out of the water for just a sec, spray some WD40 in it to stop rust, run it for another sec, then let it sit for a while. Works great, I've done it a dozen times. Motors can run under water with NO problems. |
11-22-2004, 08:14 PM | #3 |
| Re: motor cleaning
thanks and if u or an administrator can delete my other same post i just have no clue how
11-22-2004, 11:30 PM | #4 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
| Re: motor cleaning Quote:
