02-22-2011, 05:54 AM | #1 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
| Electronic advise please!
Guys, I am needing a bit of help with my current scale set up. I have a BRXL, HH 45t, Airtronics winch servo with Hayok control module, spektrum receiver, a hightec ? (410 oz) at 7.4 high current steering servo. I will be running all of this on 2200 3s 30c lipo's. This is were I need help. How do you recomment I wire my system??? My winch control is rated at 6.0 v and my steering does 300 oz at 6v but does 400+ at 7.4 v. |
02-22-2011, 06:39 AM | #2 |
Use a y harness to plug wire the BEC directly to the servo. I have mine setup like this: and it works perfectly. No need to pull the red wire from your ESC. |
02-22-2011, 06:49 AM | #3 |
So i can run the brxl @6v for the winch and use my cc bec set @ 7.4v for my steering? I didn't know if I could run both bec's????
02-22-2011, 07:00 AM | #4 |
I have my 2.2 comp truck setup that way. Just make note of which wires have been removed from that harness (one red and one black on the Rx side and one white on the BEC side) and you should be good to go. You can set the BEC to whatever voltage you wish and the Rx and ESC will still function normally.
02-22-2011, 07:16 AM | #5 |
Thanks for the quick reply and the help! |
02-22-2011, 07:17 AM | #6 |
Not a problem. Good luck with your setup! |
02-22-2011, 08:10 AM | #7 |
Pebble Pounder Join Date: Jun 2010 Location: ocala
You will still need power to the receiver and winch. It looks like the y harness does not supply power to the receiver with only a signal wire to receiver. If you use this setup you could send 7.4v to your servo but still have to get 6 volts to your winch and rec. If it is what it appears to be.
02-22-2011, 08:13 AM | #8 | |
02-22-2011, 09:23 AM | #9 |
02-22-2011, 09:27 AM | #10 |
02-22-2011, 09:44 AM | #11 |
02-22-2011, 12:36 PM | #12 |
I have never applied that much voltage to a receiver, I guess it's will work.
02-22-2011, 01:03 PM | #13 |
the reciever will only be getting 6v from the esc's internal bec not the full battery voltage of 12.6v
02-22-2011, 01:09 PM | #14 | |
02-23-2011, 05:10 PM | #15 |
My bad, wasn't thinking it all the way through my bad. |
07-07-2011, 05:25 PM | #16 |
Jeremy, I know its been a while but I ran the harness and have forward and reverse but no steering?
