03-02-2011, 10:22 PM | #1 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
| Duratrax ICE - Hack to charge more than 1c ?
Does anybody know if a Duratrax Ice can be modded or hacked to charge at more than 1c rating?
03-02-2011, 10:46 PM | #2 |
RCC Addict Join Date: Jun 2005 Location: St. Albans
Not that I know of... The only hack I've EVER found for the Ice was a EL backlight.
03-02-2011, 10:55 PM | #3 |
I wanna be Dave Join Date: Aug 2008 Location: Having fun again...
I always just upped the mah rating that the charger thought it was charging. I.E. 1100 mah hyperion battery I would charge it as a 5000 mah battery. |
03-03-2011, 05:52 AM | #4 |
Same here. Just tell it that the capacity is higher.
03-03-2011, 12:13 PM | #5 | |
That helps a lot since I've been waiting and waiting and waiting for batts charging at 1c. Takes forever to get several packs charged that way so I was getting ready to buy a new charger. The Ice still works great and I don't mind using my external hyperion balancer, so no need for a new charger. Thanks again John and Jeremy | |
03-04-2011, 07:12 PM | #6 |
Quarry Creeper Join Date: Nov 2005 Location: Planet Earth
You can lie to it as stated above and then set the capcity MAX to something less than 100% to keep the safety there. EX if you charge at 5C then set capacity to 20% if possible. |
03-10-2011, 12:30 AM | #7 | |
So much faster charging the little maxamp packs at 5c! But Chris told me not to charge his packs at more than 2c in case anybody cares | |
