Thread: unbalanced 2s lipo
Old 03-10-2011, 09:02 AM   #1
Default unbalanced 2s lipo
I've got a 2s 5800mah lipo that is showing 1.18 volts on 1 cell and 5.33 volts on the other. Is there anything I can do to save it?
MadMax5978 is offline   Reply With Quote
Old 03-10-2011, 09:09 AM   #2
Suck it up!
Duuuuuuuude's Avatar
Try to balance it. Otherwise, forget it. If you know someone who is pretty familiar with lipo's, they might be able to bring the low cell back up.
Duuuuuuuude is offline   Reply With Quote
Old 03-10-2011, 09:16 AM   #3
I dont know 1.1 volts... if you do try and balance it out do it outside away fom anything you dont want to burn down
Diesel-tech is offline   Reply With Quote
Old 03-10-2011, 09:20 AM   #4
If your charger has a recovery mode, try that first.
1.18 is pretty damn low, you've lost 2/3 of the cells nominal voltage.
Duuuuuuuude's right, if you don't have the facility to attempt a recovery find someone who does...perhaps your local shop, and let them try.
Just curious, what brand Lipo is it?
CreepyCrawl is offline   Reply With Quote
Old 03-10-2011, 09:26 AM   #5
that just happened to me 2 days ago on a 2s, it was a blue lipo, cheap but i had it over a year, i just threw it away and ordered a few more of them, just a bigger mah rating.
jon1197 is offline   Reply With Quote
Old 03-10-2011, 11:06 AM   #6
[QUOTE
Just curious, what brand Lipo is it?[/QUOTE]
tURNIGY
Old 03-10-2011, 11:16 AM   #7
Originally Posted by MadMax5978 View Post
tURNIGY
What charger are you using? How did it get that unbalanced?
SMR 510RR is offline   Reply With Quote
Old 03-10-2011, 12:15 PM   #8
+1.
Does your ESC have a LVC? If so, what is it set for (2S, 3S,.....)?
Charlie-III is offline   Reply With Quote
Old 03-10-2011, 12:18 PM   #9
Are you certain that the shown voltage is correct and not an error on the part of the charger?
JeremyH is offline   Reply With Quote
Old 03-10-2011, 03:02 PM   #10
Originally Posted by Charlie-III View Post
+1.
ESC wasn't set for lipo and grandson ran the slash with the lipo instead of the nimh and I wasn't home and he didn't know the difference (I've got two slash's 1 with lipo and one without)
Using a meter from my LHS that shows each cells voltage.
iMax B6 charger and does have a lipo recovery setting
Thanks for all the help but looks like I'm out a battery
Going to sit the grandson down tonight and explain the differences in the batteries.
Old 03-10-2011, 03:29 PM   #11
Ok...good.
If it were me, I'd charge that pack for a few seconds on NiMH to bump up the voltage and then switch to Lipo...
Old 03-10-2011, 03:34 PM   #12
You can charge only the low cell thru the tap on ni setting. Once its up on voltage balance charge it. Outside on concrete. Just in case.
thatguy is offline   Reply With Quote
Old 03-10-2011, 03:35 PM   #13
Suck it up!
Ok...good.
Wouldn't this work?
Old 03-10-2011, 03:42 PM   #14
Originally Posted by Duuuuuuuude View Post
Wouldn't this work?
I dunno....never used that. My charger simply wont recognize a pack that has dropped below the LVC (or whatever voltage it deems as recognizable)...
Old 03-10-2011, 05:14 PM   #15
1-I'm glad my son didn't get into some of my stuff when he was younger.
2-I don't have any grandkids (at least, not proven in a court of law.....), but I do have a teenage son (also on this forum). Be nice to your grandson, he can learn a lesson while NOT getting PO'd at you. Remember, it may be tough for some to replace a battery pack (times are tight, RC batteries tend to be near the bottom of the list of "essentials....") but an impression to a younger person tends to be LIFELONG!!
Look at the bright side, at least he didn't CHARGE the LiPO at a NiMH setting and burn down your house!
Old 03-11-2011, 06:43 AM   #16
Charlie good point
I had a nice talk with him last night and he now understands. He's 15 and was like what's the difference, he figured a battery was a battery. So he now is a smarter 15 (kinda like staying at a Holiday Inn Express)
Old 03-11-2011, 10:36 AM   #17
wierd im having a simalar problem,it just happens to be that i have a 3s hobby people 2200mah 20c 11.1v . just started here in the elec. section to do some searching and rite off i seen this post so here i am , my charger is a sigma II eq and reading thru it i founnd it come equipped with a balance setting so i set it up all outside to try will post more if it works.
78bucket is offline   Reply With Quote
Old 03-11-2011, 11:17 AM   #18
1.18 volts is low for sure, but what about the 5.33 volts on the other cell, I would be more worried about that. With the low cell u just have to get rid of it, but with overcharged cell, doesn't it have to possibility of it igniting? From what I understand, 4.2 volts per cell was max. If u have anyother way of checking the lipo cells(charger read out or multimeter), I would do that and make sure your volt meter that u are using now is correct. One other thing, how did your battery get charged up so high in the first place? After the battery was run, 5.33 Volts is still higher than my charger would ever take it. Good luck and let us know what u end up doing.
Chevdog is offline   Reply With Quote
Old 03-11-2011, 12:07 PM   #19
Suck it up!
If you aren't using a balancer, the charger will just throw voltage to the battery. It doesn't care if it is equally distributed across the cells or all packed into one. All its going to see is the voltage of the battery as a whole.
Charge a battery enough times without balancing and it will go way out of whack. The weaker cell will discharge further when used, and not hold a charge as well when its juiced back up.
