03-11-2011, 07:22 PM | #1 |
Newbie Join Date: Feb 2011 Location: Green Bay
| Lipo Questions!!
I have a scx10 tr dingo and it is mostly stock exept a Spektrum dx3e transmitter and receiver and I am not sure if my truck is lipo ready? Also I am not sure what size lipo to get? And would not like to spend mor than $60? Any input or advice would be awesome!!!! |
03-11-2011, 08:00 PM | #2 |
Quarry Creeper Join Date: Feb 2008 Location: Plano. Il
I've seen people run 2's lipo without a problem, but I don't think those esc's have a lipo cut off. You might have to pick up a new esc or a low voltage cut off for your rig. Don't know if your charger can charge lipo's or not but you might have to look into that to.
03-11-2011, 08:27 PM | #3 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
Do you know what ESC you are running? If it is a stock axial esc then take a look at it, if it's an AE-2 then it has a low voltage cutoff for 2S lipo, if it's the AE-1 then there is no cutoff and you will have to use an external cutoff or alarm or buy a new ESC like sdmf7 said. If you already have a lipo compatible charger then check out these websites for good quality inexpensive batteries: www.cheapbatterypacks.com www.valuehobby.com www.hobbyking.com www.hobbypartz.com If you need a charger I would look at the Thunder AC6 charger from hobbypartz.com |
03-12-2011, 09:14 AM | #4 |
What is a lipo cutoff? Haha sorry I'm such a noob, and I am running the AE-1
03-12-2011, 09:20 AM | #5 |
Quarry Creeper Join Date: Mar 2010 Location: Bridgeport, CT
03-12-2011, 09:22 AM | #6 |
Quarry Creeper Join Date: Dec 2009 Location: jackson,tn
I ran my rig with the stock ae-1 for about 15 mins with a 2s 2650mah lipo, it glitched very bad, it would be alot smarter just to buy a new esc and easier also. Jus my .02
03-12-2011, 09:36 AM | #7 |
| Lipos don't cause glitches. You've got something else going on. I've run 3s through the ae-1 with no problems at all.
03-20-2011, 11:37 AM | #8 |
Can u maybe tell me of some esc's that are fairly cheap that have a lipo cutoff?
