Thread: 4pk on a micro
Old 03-12-2011, 09:16 PM   #1
Default 4pk on a micro
posted int he micro section, but figured maybe id have better luck here.
Anyone ran a losi micro crawler with a 4pk? I got a 4pk sitting around from Christmas, and since my xr10 is on hold for awhile, im wanting to see if i could use it on my micro, just have no clue where to start
humanmachinehead is offline   Reply With Quote
Old 03-12-2011, 11:11 PM   #2
Just take the receiver out of the micro and put in your new futaba receiver then setup your radio accordingly. All the connections for the servo and esc are standard so it's a simple swap job.
forbid89 is offline   Reply With Quote
Old 03-13-2011, 08:47 AM   #3
some of the things are hard wired tho, so they dont just unplug. the steering servo is the only thing that will unplug
Old 03-14-2011, 02:47 AM   #4
Sorry for the bad advice, I didn't realize it had a integrated esc/rx. Doesn't look like there is an option without replacing the esc. You might want to ask in the losi micro crawler forum, I tried searching in there but didn't turn up anything so unless there is a hack of some sort looks like a new esc would be your only option.
Old 03-14-2011, 10:48 AM   #5
the only way you can run it with your 4pk is to get a new esc for it to plug into your futaba rx along with the steering servo
benoj is offline   Reply With Quote
