03-16-2011, 12:01 PM | #1 |
Rock Stacker Join Date: Jan 2011 Location: hellinois
| rc4wd dig problem.....
not a radio issue.spoke with custumer service and i have it set right.now it going to be a rocker dig problem,but no support thru the maker rc4wd only thru e-mail...yada yada yada.this sucks.this is the 2nd one sent to me and same problem,i have my 3rd channel set as a 3 way position switch now in N both motors turn flip the switch up pos. 1 it engages front motor,turns like it should .flip the switch to pos.3 theres nothing .the rocker does come with a light set up built in. the lights cycle thru correctly like they should. the front dig works great but i have no rear dig,cant even get any type of reading from rear switch of the dig unit .volt meter or a test light. has anyone else come accross this before? |
03-16-2011, 06:09 PM | #2 |
Newbie Join Date: Jan 2011 Location: redgranite
I just installed mine tonight and I have the same problem. Would love to know the solution or if its just faulty.
03-16-2011, 06:18 PM | #3 |
What is the percentage travel for that third channel? When I ran electrical dig units, I always turned the travel on my dig channel all the way up (150% or so).
03-16-2011, 09:37 PM | #4 |
Plug a servo (even if it is your steering servo) into CH3 on your receiver. Verify that you get three positions out of it. As was said, you might have to extend the travel on that channel. Could also try plugging the dig unit into your steering channel and see if you can get three modes out of it by moving the steering wheel. Make sense? This could help you decide where the problem might be. |
03-16-2011, 11:37 PM | #5 |
Rock Crawler Join Date: Dec 2005 Location: houston
Installed mine about 3 days ago, same problem. Front dig, four wheel drive, but no rear dig. All the lights on the rocker dig switch are operating properly but no power output when switched to rear dig, I even tried another radio with no luck. I was able to contact them through e-mail, and will be sending it back, kinda sucks because their shipping was very slow the first time, so no telling how long this will take. It is the new rocker dig II BTW.
03-17-2011, 06:58 AM | #6 |
this is bs.i know all my stuff may not be top of the line but all my parts are from the same manufactor RC4WD.so you would think they have put together some of their own parts to see if they work together.the first dig they sent me was version 1 of the digs the 2nd one is version 2,flipped out on the guy on the phone ,how they gonna sell something that has problems and not say anything,till there was a problem then try to blame it on there being a problem with version 1 dig..needless to say ill never buy any of there stuff again....rc4wd and your products/support via email only. what a shame |
03-17-2011, 07:25 AM | #7 |
Has anyone in this thread actually tried to adjust endpoints, double check solider joints, try another rear motor or anything else for that matter? Or are you gonna just bash on RC4WD? Maybe at times their customer service over the phone needs a little help. Y'all ain't the only customers. They do have several team drivers on RCC, maybe they can be more helpful? |
03-17-2011, 08:06 AM | #8 | |
03-17-2011, 08:24 AM | #9 |
03-17-2011, 08:36 AM | #10 |
just fustrated....
03-17-2011, 08:37 AM | #11 |
| So, you get full throw on each side when you plugged it into the servo? Then it sounds like the dig is working properly. If so, then it sounds like there might be an issue with the motor connection (where it goes into the dig).
03-17-2011, 09:44 AM | #12 |
For the record, RC4WD has been very helpful and prompt with me as far as e mail communication. Within two days of initiating contact and checking a few things, they have instructed me to send the unit back and that they would send me a new one as soon as I shipped mine. That is pretty darn good service if you ask me. However, their shipping was rather slow, and I am not too terribly impressed with the product obviously. Heres where I am confused as to whats happening with the dig. Apparently the relays are both good because the 4WD works, if one was bad it wouldnt work at all ( correct me if im wrong ) also the solder joints have to be good to the motor or it wouldnt work at all either. The LED's on the unit switch like they are supposed to as well, just no power to the rear wheels when rear dig only is selected. I did try another radio, and I also adjusted my epa's to see if that would help. Doesn't make much sense to me, so I'll send it back and hope the new one works better. On a side note, this is my first MOA. How strong should the dig brakes be?? The rear tires still seem to roll pretty easily. I have noticed that in 4WD the rear tires are much harder to turn by hand while the drag brake of the ESC is holding, but when switched to front dig where the dig unit is holding, the wheels roll much easier. Does that sound normal? Or do other units (punk dig) hold pretty strong? Thanks for the help! |
03-17-2011, 11:26 AM | #13 | |
03-17-2011, 04:31 PM | #14 | |
That's another plus to going dual ESC's. Nomatter what your doing, you can dial the front or rear motors in or out to hold as tight or as loose as you want/need. | |
03-17-2011, 07:26 PM | #15 | |
Great, thanks for the info! | |
03-30-2011, 07:38 PM | #16 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver Wa, USA
Put me in line. I emailed RC4WD and asked if they had fixxed their Dig II problem of No Rear Dig. They emailed me back stating that they had had problems with only a few of their Dig II's. So, I ordered one, I got it today, installed it and ...... No Rear Dig ! Front Dig ... OK. 4WD ... OK, Just NO rear dig ? Dig lights all lite up and seem to be switching and working correctly. I am using a RC4WD XR4 radio. I am using Ch#3 it is a 3 position channel. I emailed RC4WD, so will see what they say to do. How has everyone else fixxed this situation ? RC4WD repair or replace ? "If" replaced, new one work OK ? Thanks Smitty |
03-31-2011, 03:29 PM | #17 |
Don't they test these before they send them out ? Quality control ? Just wondering out loud. Smitty |
04-07-2011, 06:51 PM | #18 |
OK, just got the replacement RC4WD Dig II in and installed it. Same problem, "No Rear Dig" Now what do I do ? This is the second one that has No Rear Dig. Try for the third time's a charm ? Ask for a refund ? I am happy RC4WD responded so quickly and sent another Dig II out so fast, it's just that this one is broken also. I think I will try one more then ask for my money back. |
04-07-2011, 07:42 PM | #19 | |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
I would ask for a refund personally. Way too many problems with their dig units. I hear the dig doesn't put very much brake on the motor as well when they do work. Go Punk or one of Heyok's units. Never any issues with any of my Punk digs. Haven't had a chance to try the Heyok unit yet. | |
04-07-2011, 07:55 PM | #20 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
