03-17-2011, 01:34 PM | #1 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
| Axial AE-2 Lipo cutoff question
I have an AX10 running stock electronics, AE-2 ESC, 55T motor and the stock Axial servo. While I'm waiting for my larger batteries to arrive I was running a small 360mah 2S 20C lipo. I ran one pack until the it died and left it overnight, the next day when I went to charge it and my charger gives me a low voltage warning and refuses to charge it. Now I have read in the AE-2 instructions that the 2S lipo cutoff is enabled from the factory so I'm wondering why this happened? Is is possible the lipo cutoff is off or was I pushing this small pack beyond it's limits? I don't have a castle link to check the settings but I may have to go out and get one to make sure, I don't want to be killing all my lipo's.
03-17-2011, 01:37 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: Phoenix
Did you leave the battery plugged in to the ESC overnight? if so that is what caused it to over discharge, i would highly recommend getting the castle link it makes changes very easy to do
03-17-2011, 01:41 PM | #3 |
Yes I did, it will still continue to discharge even with ESC switched off? Looks like I better track down a castle link in the near future also.
03-17-2011, 01:44 PM | #4 |
yeah it will have a small draw even if the switch is off, lipo's need to be unplugged after you run them to prevent this, I remove the on/off switch so I have to unplug the battery after running it is a good helpful reminder.
03-17-2011, 01:54 PM | #5 |
God I feel pretty stupid now but thanks for the help, good to know. I will probably cut off the switch or just heatshrink over it.
03-17-2011, 01:58 PM | #6 |
don't beat your self up too much I have done it more times than I can count on my savage. You just remove the switch and connect the 2 wires and cover them with heat shrink tube
