03-19-2011, 03:43 AM | #1 |
Quarry Creeper Join Date: Apr 2010 Location: Centurion, GP, RSA
| RC4WD 35T can motor timing
What is the timing on these motors? I noticed that on my Bully that the rear turn faster than the front although the front has 12T pinion and the rear 11T. The front motor is wired normal but the rear has the polarity swopped for motor to run in correct direction. Do I need to change the timing on the rear motor? I also get lots of stall from the rear suggesting from the symptoms that the wheel speed is high with little torque. I currently run the ESC from Nanda Pathfinder crawler. This ESC is simmilar to the dual motor ESC sold by RC4WD. I will be changing to a Tekin R1 ESC shortly. Any suggestions. |
03-19-2011, 03:58 AM | #2 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
I have no idea what they run as stock timing. But they are a sealed can fixed timing motor. So adjusting the timing is out unless you want to try and crank the comm (which has got a high potential to screw up your motor) I wonder if the incorrect sticker has been put on the can so the rear motor is a different wind to the one you have in the front. Someone else might be able to chime in with a way to help you out. |
03-19-2011, 05:52 AM | #3 |
Sucky way to see, but try swapping the motors front to rear?
