03-19-2011, 09:47 AM | #1 |
Newbie Join Date: Feb 2011 Location: The South
| GT3b Radio/Receiver Problems
I just bought a gt3b radio etc. On page 7 of the manual it shows how to connect your ESC and servo and battery - I followed the instructions exactly and I think I fried my receiver. I put the ESC into the channel 2 slot and a servo into the channel 1 slot on the receiver. I had a motor hooked up and a 7.2 volt battery. Im using a older novak rooster reversible esc I bought in the mid 90s. The radio would not talk to the receiver and I noticed the receiver was getting very hot so I disconnected everything. According to the manual the receive was bound at the factory and should work fine? I have done exhaustive searches on the web and can not find what I am doing wrong here. I have been out of this hobby for 15 yrs so I am a bit behind the technology curve. I can post pictures if it will help - be back later. Thanks in advance to anyone that can help....
03-19-2011, 10:58 AM | #2 |
its possible you got a bad rx because from what i understand everything was hooked up correctly and extra rx's are cheap they are like $8
03-19-2011, 12:43 PM | #3 |
Quarry Creeper Join Date: Jun 2010 Location: Elk Grove
X2 on the possible bad receiver, I use a GT-3 and I have one rx that gave me some issues once. Does your esc have a built on BEC? Could it possibly be faulty, letting the battery's full voltage pass to the rx? Those rx's are rated to 6v, anymore and they fry pretty quick.
03-19-2011, 01:54 PM | #4 | |
Thanks for the response guys - I will try to track down the specifications for this old Rooster ESC - just might be the culprit here... Quote:
07-20-2011, 12:43 AM | #5 |
Got my radio the other day and just set it up in my Honcho. Got it bound, steering trimmed, steering endpoints set, reversed channel 2 (throttle) and it works but will not save this setting! WTF? Reset it 10 times and it won't stay reversed! |
07-20-2011, 12:53 AM | #6 |
Newbie Join Date: Jul 2011 Location: Canton
Ok I just got one yesterday and it took me about 4 hours to figure out you put the Esc-Battery plug into vcc not into channel 2 where it should and will go. The instructions suck but once i figured that out mine works like a champ.
07-20-2011, 01:48 AM | #7 |
| Uh you mean the esc goes in channel 2, and rx battery (if you use one) goes in channel 3?
07-20-2011, 03:33 AM | #8 |
Basicly when binding you plug your esc into the VSC port and the bind plug in in bind. Once bound turn off esc then radio put esc into number 2 slot pull bind plug turn radio on and then turn on esc and it stays bound I even transfered the reciver between multiple vehicles. If you use rx battery plug that in vcc and dont even plug the esc till bound. Id like to thank youtube and this guy http://www.youtube.com/watch?v=BXKC5wffI44. |
07-20-2011, 06:26 AM | #9 |
there is also a tutorial on Hobbypartz web site on how to set it up,
07-20-2011, 10:49 AM | #10 |
How many volts are you sending to the RX? Are you using the BEC in the ESC or are you using an external BEC? . The rx is rated to only 6v per manufacture specs, I haven't tried mine at anything more than 6.1, just a thought.
07-20-2011, 11:20 AM | #11 |
Rock Crawler Join Date: Dec 2005 Location: houston
I accidentally hooked mine up with too much power going to the rx through the bec, it immediately shut down and wouldnt respond. I heard a small pop noise when it happened, which meant one of two things.... I either popped a component in the rx , or it has a circuit breaker built in. I took the cover off the rx to inspect and nothing appeared burnt or smelled burnt, but I did notice a small silver component on the board that resembled a circuit breaker. So, I let the rx sit for a while hoping that if it was a breaker it would reset. Sure enough, after a few minutes I plugged it all back together with the proper voltage and it was working fine again. |
07-20-2011, 07:03 PM | #12 |
I wanna be Dave Join Date: Feb 2007 Location: South FL
07-20-2011, 07:30 PM | #13 |
Actually, Im not sure. I bought a used CC BEC and asked the seller to set it to 6 volts before he shipped it. I am assuming he did, but I did not check the output voltage so I cant be positive. Anyway, when I hooked it the rx it immediately popped. I just rewired the BEC straight to the servo so it doesnt plug into the rx anymore.
07-21-2011, 03:09 AM | #14 |
RCC Addict Join Date: Mar 2007 Location: Turn the mayflower around.. it will never work
| You didnt save it...... if you dont save and then close menu out it will return to where the original setting was.
07-21-2011, 03:48 PM | #15 | |
EDIT: OK...that's why I shouldn't work on things like this late at night. Little help from a friend and got it figured. Turn on radio, push ENTER, twist knob to REV, push ENTER, twist knob to select channel, push END and the FWD or REV will flash (whichever one it's already set to), twist knob to select which you want (REV or NOR), push ENTER, push END, push BACK and it's saved...you're done or you can then adjust the other servo forward/reverse, etc. Great little radio for the money, but the manual sucks...takes some reading, tinkering and sometimes a little help from friends to figure it all out! Last edited by Natedog; 07-21-2011 at 10:23 PM. | |
07-21-2011, 11:33 PM | #16 | |
