Thread: Not a crawler motor.. but how are these??
Old 03-27-2011, 03:15 PM   #1
Default Not a crawler motor.. but how are these??
http://www3.towerhobbies.com/cgi-bin...?&I=LXALPL&P=0
im looking for a cheap 27t thats better than the stock axial ones.
anyone have any expierence with these?
thanks
ninetwofiveRC is offline   Reply With Quote
Old 03-27-2011, 03:38 PM   #2
Not much different than what you are running now. Biggest difference would be replaceable brushes.
Manning is offline   Reply With Quote
Old 03-27-2011, 03:45 PM   #3
depending on what your going to use it for? If you plan on crawling with it, id suggest gettng a 35t motor. a 27 can burn up on the rocks if geared wrong...
Twiztid Metal is offline   Reply With Quote
Old 03-27-2011, 06:00 PM   #4
Uhhh....thats not true. Its a stock motor so it has 24* locked timing. Big difference to the silver can that axial puts out.
ninetwofiveRC - I would steer clear of it in anything that will see reverse. Those motor wear out quick if you run it in reverse due to the locked advanced timing.
But if you dont care, get it. It will be scream while it lasts.
WIDELOAD is offline   Reply With Quote
