03-27-2011, 03:15 PM | #1 |
Quarry Creeper Join Date: Dec 2009 Location: Brentwood
| Not a crawler motor.. but how are these?? http://www3.towerhobbies.com/cgi-bin...?&I=LXALPL&P=0 im looking for a cheap 27t thats better than the stock axial ones. anyone have any expierence with these? thanks |
03-27-2011, 03:38 PM | #2 |
Not much different than what you are running now. Biggest difference would be replaceable brushes.
03-27-2011, 03:45 PM | #3 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
depending on what your going to use it for? If you plan on crawling with it, id suggest gettng a 35t motor. a 27 can burn up on the rocks if geared wrong...
03-27-2011, 06:00 PM | #4 | |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Uhhh....thats not true. Its a stock motor so it has 24* locked timing. Big difference to the silver can that axial puts out. ninetwofiveRC - I would steer clear of it in anything that will see reverse. Those motor wear out quick if you run it in reverse due to the locked advanced timing. But if you dont care, get it. It will be scream while it lasts. | |
