03-30-2011, 09:01 PM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Over at yo mama's house
| Need 10T puller help!!!
Hey guys. I have a motor question for you. I have a scx10 scaler that weighs 6.5 lbs. I am running a stock axial tranny with a 87tooth spur and 18tooth pinion. It is coupled to a GCM t-case, 1:1 ratio. I had a firebolt 15T motor fram a Blitz that I was running with a 2s lipo and it had great wheelspeed but not good dragbrake. I purchased a HH 10T cobalt puller motor to put in this to get more speed, better torque, and better dragbrake. I changed the pinion to a 14tooth and left the stock spur gear. The 14tooth pinion was recommended by JRH in a different thread. I also put a 3s lipo pack in it. My problem is, it doesn't have near as much wheelspeed as it did before. I'm stumped. Can anyone think of something I am forgetting? I really expected a bigger difference than what I'm seeing. The drag brack is much better, but the wheelspeed is way off, from what I'm seeing and have looked up. I left everything the same other than what I stated above. I'm hoping it is just a bonehead thing that I'm overlooking. Thanks for the help. Dan |
03-30-2011, 09:06 PM | #2 | |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
well I would try and change your spur to pinion set up. just keep experimenting until you get to what you want with out burning up the motor , battery or speedo. It sounds like your in the right place. The Puller is more along the lines of what it says it is. a power horse motor built for torque and power. Speed is really not the main design, but dont get me wrong. geared right it can be good. maybe try a 4S instead. what kind of speed are you looking for?? Quote:
03-30-2011, 09:22 PM | #3 |
Just something a little nit more than it had before. Witht he 15T motor i had to walk pretty fast to keep up. With the 10T puller I can walk at a fairly normal pace and it just barely gets away from me. Am I expecting more wheelspeed than it is supposed to have? I just maybe thought it would have more. As far as the 4s, it says it is only rated for 2s-3s. I'm not sure it would be a good idea to do that, idk? If JRH chimes in and says it will handle it no prob, then I may go that route. When we go scaling, we go for quite a while so I don't want to over work the motor. I usually take 2 4000mah 2s batteties with me. 1 in the truck and 1 spare. Thanks for the input. Dan |
03-30-2011, 09:25 PM | #4 | |
You might be quite right. I thought some people had pushed 4S through therm. what ESC are you running? Quote:
03-30-2011, 09:33 PM | #5 |
CC Sidewinder with CC bec. It has incredible torque as you said. I already stripped 1 spur and am pretty close to doing it again. Well I'll try again in the morning. Thanks for the help. Dan |
03-30-2011, 09:35 PM | #6 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Up the pinion and see how you like it. Just watch the motor temps.
03-31-2011, 06:39 AM | #7 |
Yeah, I thought about trying that. I was also thinking about changing the spur to a HR spur and hopefully it won't strip quite as fast.
03-31-2011, 07:09 AM | #8 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
The Lipo that you're running will make a difference as well....what's the C rating on your pack? From Johns site: Recommended lipo battery- 6t- 2s only. 40a continuous 7t- 2 to 3s (3s may result in overheating). 45a continous 11.1v, use 35a continuous 7.4v use 10t- 2 to 3s. 40 amps continuous 11.1v use, 30 amps continuous for 7.4v. 14t- 3 to 6s. 35a continuous 22.2v use, 25a continuous 3s use 6t- TBD 7t - 2800 rpm/volt 10t- 1800 rpm/volt 14t- TBD Just as an example, in my 8 pound Yota I'm running an Integy V11 35T with stock 14/87 gearing on a Thunder Power G4 45C 2250mAH 3 cell. At full clamp I have to run to keep up with it. C ratings do make a difference. |
03-31-2011, 07:37 AM | #9 | |
You make a good point. I didn't think about the C rating. Both 3s batteries I'm using are 25C rated. I may need to get another battery. Thanks for the help. Dan | |
03-31-2011, 09:10 AM | #10 |
I hadn't seen it mentioned yet, but the wind counts on Pullers are not equal to typical 540's. The 15t Blitz motor was probably somewhere in the 2500+ kv range, while the 10t Puller is rated at 1800kv. You'd have to step up to the 6 or 7 turn Puller to have similar motor speed with the same amount of voltage. |
03-31-2011, 10:16 AM | #11 | |
03-31-2011, 08:31 PM | #12 |
I got it. So basically, the puller is going to be a ton stronger but may not be as fast as the 15T blitz. I understand. Next I guess I'll have to order a 7T. But I tell ya, I love this motor. The drag brake is great and it is strong. Thanks to everyone for the input and for the help. It makes better sense now. |
03-31-2011, 08:56 PM | #13 |
04-08-2011, 11:38 PM | #14 |
Rock Crawler Join Date: Jan 2006 Location: Southwestern Pa.
I just ordered a 7t puller to go in Rock Rod, my TTC scaler. I started running 6s with a 55t Torquemaster....Very powerful, but way too wicked on brushes and commutators. The 7t on 3s ought to be the ticket. |
04-09-2011, 04:12 PM | #15 |
One question....My current 6s lipo to a 55t HH Handwound....Will it be more or less powerful than the 7t Puller motor on 3s 35c/ 70c burst? Debating my axle selection as it is using Axial CVD's with music wire pins that work well, but I am contemplating selling a new set of SDS axles because I got the Axials to work.......HELP!
