04-01-2011, 12:57 PM | #1 |
Pebble Pounder Join Date: Jun 2009 Location: Shenandoah Valley, VA
| using throttle trim to drag brake
Is it OK to set throttle trim to create drag brake on a non-drag brake esc? I tested with the throttle trim toward reverse, causing a 'hum' when setting still, and it did drag brake coming down a hill. I have a Duratrax Auto-Sport with reverse. |
04-01-2011, 01:46 PM | #2 |
Not the best bet, but yes, it works. You may wear out your trim over time though. |
04-01-2011, 01:52 PM | #3 |
Quarry Creeper Join Date: Jan 2009 Location: Estonia
Well I tried that too, but eventually it had a bad effect on run-time. That will cause motor to draw power from battery all the time and it drains the battery alot faster. I didn't like it. |
04-01-2011, 03:09 PM | #4 |
RCC Addict Join Date: Aug 2007 Location: Seattle
It's usually a better result to get the trim to almost creep the truck forward. Sounds crazy but it's worked for my HPI speed controls.
04-01-2011, 04:11 PM | #5 |
04-01-2011, 04:22 PM | #6 |
Quarry Creeper Join Date: Jul 2010 Location: Where Jeep axles are made
another problem is if you have it backwards and ur going up a hill a stop it will go backwards faster |
04-01-2011, 05:36 PM | #7 |
04-01-2011, 05:36 PM | #8 |
04-01-2011, 09:50 PM | #9 |
Quarry Creeper Join Date: May 2009 Location: Under Communist Occupation
$20 for an HPI gear reduction unit will give you your drag brake, and an obscene amount of torque.
04-01-2011, 11:56 PM | #10 |
Before there was drag brakes that's what we used to do, use the trim to put a little drag on it when needed.
04-02-2011, 05:02 AM | #11 |
04-02-2011, 10:34 AM | #12 |
Aint that the truth!
