04-02-2011, 06:25 PM | #1 |
Rock Stacker Join Date: Mar 2011 Location: WA
| Hitec 7950tg voltage
Hi, Picked up a 7950TH and a CC BEC. I have the castle link so my question is should I run the full 7.2 volts (I have a 614 receiver so it can handle 8.4) or should I run a bit less? Will running at the full 7.2 have an adverse affect on reliablity? Thanks! |
04-03-2011, 01:46 AM | #2 |
Newbie Join Date: Jan 2011 Location: Australia
Its rated to 7.4v. Heres the link to their site. http://www.hitecrcd.com/products/dig...hs-7950th.html |
04-03-2011, 07:29 AM | #3 |
Rock Crawler Join Date: Oct 2010 Location: triad
i turned mine up to 7.4v and i don't know what was going on, but my entire rig would shut down and start up, shut down, steering would stop and come back on, ESC would stop and come back on... so i cut it back to where it was (stock) and it works great.
04-03-2011, 09:27 AM | #4 |
RCC Addict Join Date: Jan 2008 Location: Apple Valley,CA
| I am also running the 614ff and a 7950. They are rated for 7.4v (2s lipo) but I have local buddies with factory support who actually run them at over 8volts. You will be fine running yours at 7.2 as you stated or 7.4 and running it through your 614ff. I personally am running mine at 7.2 through my 614ff and I have my OLP set down to 20%. |
04-03-2011, 09:43 AM | #5 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
Seems everyone forgets but a freshly charged lipo is not 7.4 volts.........................it is 8.4 volts fellas. 3.7 volts per cell is the nominal voltage. I run my 7950 at 7.4 volts(1 volt less than straight off a fully charged lipo) through a 614 rec. with absolutely no problems. Last edited by Scattman; 04-03-2011 at 09:46 AM. |
04-03-2011, 09:49 AM | #6 | |
They are actually running them at a voltage close to what a charged lipo actually puts out when fully charged, 8.4 volts, which is still within specs although the lipo would gradually drop some voltage whereas the bec's they are running supplies the 8+ volts continuously throughout the run. Last edited by Scattman; 04-03-2011 at 09:55 AM. | |
04-04-2011, 10:33 PM | #7 | |
sorry i'm a newbie, what's that? | |
04-05-2011, 09:26 PM | #8 |
OLP is the "OverLoad Protection" that you can set using a Hitec Hpp-21 programmer module. You hook it up to your PC and to your servo and you can adjust things like your center position, epa's, deadband, OLP, etc. Here is a link for some reading: http://www.servocity.com/html/hpp-21...rogrammer.html |
04-05-2011, 11:43 PM | #9 |
Thanks for the information, it's very much apprecaited. Just read about the Castle/Hitec servos.. not very happy |
05-27-2011, 07:14 PM | #10 |
Rock Crawler Join Date: Mar 2010 Location: Hampton
so are most people running the 7950 at 8.4? i am just about ready to swap my 7955 that is on 7 volts over to the 7950 and was curious about what to set it at. the 7955 worked great on my berg but when i switched to the xr it just does not cut it.
05-27-2011, 08:13 PM | #11 |
Rock Crawler Join Date: Jun 2009 Location: Minnesota
8.4v here |
05-28-2011, 01:24 AM | #12 |
Quarry Creeper Join Date: Apr 2011 Location: United States
did you pull the power wire from your esc?
05-31-2011, 07:23 AM | #13 |
Rock Crawler Join Date: Jan 2010 Location: In the lair editing video
Just thought I would chime in with my experience. My 7950 on a CCBEC was also resetting and shutting down my Rx. It did this at 6v and 7.4. My BEC was pretty used so I bought a new one and everything seems great at 6v. I guess my old BEC couldnt take the heat.
05-31-2011, 12:13 PM | #14 |
| Were you wired from the BEC direct to the servo, or through the RX??
06-07-2011, 06:00 PM | #15 |
06-07-2011, 07:35 PM | #16 | |
I wonder if it's related to RX brand?? | |
06-10-2011, 07:52 AM | #17 |
Newbie Join Date: Jun 2011 Location: Sydney
Excuse the ignorance from this question but I'm new to becs and the world of high voltage servos... What's the deal with amp output from an esc to power a servo? Or is it just all about voltages? Eg I'm building a kit, and want to know what gear to whack in my rig...eg Novak rooster crawler or tekin fx, mamba max pro etc etc. The problem is I already have a 7950th servo from hitec and everyone reckons it's a volt hungry beast that won't operate without a Bec? I've seen the diagrams to install one, my question is do I need to with any of the above three speed controls? And also, what amperage does a high voltage servo like this need to run at without shutting everything down? Any help would be awesome, maybes there's another thread to anwser this, I couldn't find it haha. |
06-10-2011, 08:37 AM | #18 | |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
06-10-2011, 12:59 PM | #19 | |
Well of course the voltage drops some when under a load. And different loads will drop it to different voltages, 3.7 volts is not some magic number that all lipo's fall to when under load. Lot of different factors that go into it as well like pack mah and discharge rate. | |
06-10-2011, 02:16 PM | #20 | |
