04-11-2011, 05:49 PM | #1 |
Rock Stacker Join Date: Jan 2009 Location: simi valley, ca
| This may be a stupid question but.....
If you are running a 6cell 7.2v battery and you wanted to run your servo on 7.2v why would you need a BEC if you wired your servo straight to the battery like some people do when using a BEC? I am sure I am missing something here but does the BEC do anything else besides stepping the voltage down when using big volt batteries?
04-11-2011, 05:56 PM | #2 | |
Back before you could buy a BEC we used to wire the servo directly to the battery. Some servos would live and some would burn up. | |
04-11-2011, 05:56 PM | #3 |
Rock Stacker Join Date: Nov 2008 Location: Rock Springs
The CC because has a higher current than most internal because. This can produce a more consistant current to the servo. It is more important to use an external because when using 3 or 4 cell lipo.
04-11-2011, 07:30 PM | #4 | |
I had noticed that too but I thought it might drop down to 7.2 as soon as it got some load on it. So you are saying it might work but could burn up the servo. The servo in question is a stock axial AS-2, word on the street is that it is a rebadged futaba. Any guesses at to it's life span if I tried direct powering it. | |
04-12-2011, 06:31 AM | #5 | |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
It "could" work, but I would not chance it. Even the high end servo's don't like that much voltage. | |
04-12-2011, 06:43 AM | #6 |
RCC Addict Join Date: Mar 2010 Location: Alburtis
I am running 7.4v to my servo. However, it is rated for it and I am using a CCBEC. The other advantage is the voltage remains at the programmed voltage as long as the battery voltage is above the programmed voltage. So, the servo should work the same at fully charged and a run down pack. Wes |
04-12-2011, 10:32 AM | #7 | |
04-12-2011, 10:53 AM | #8 |
Rock Crawler Join Date: Aug 2006 Location: Pinedale, WY
Its only 20 bucks + shipping
06-18-2012, 09:55 PM | #9 |
Rock Stacker Join Date: Feb 2012 Location: Colorado
| Re: This may be a stupid question but.....
So it is still wise to run a BEC even with a 6 or 7 cell NiMH? I just assumed these were only for lipo rigs.
06-18-2012, 10:31 PM | #10 | |
Quarry Creeper Join Date: Jul 2009 Location: Buffalo area
| Re: This may be a stupid question but..... Quote:
Its a good idea just because the CCBEC provides a constant, regulated voltage to the CONTROL end of your servos/steering, right up until the voltage drops so low that things just shut down. (low voltage shut-off) Bad things happen when you lose that control........... LOL! But it dont help if you dont wire it correctly.......... To answer your question, YES!!!! ALWAYS!!!! Its only 20 bucks of insurance FCS! BUT, wire it correctly, with a COMMON GROUND!!!! | |
06-19-2012, 12:20 AM | #11 | ||
The current required can alternatively be provided by cheaper BECs that are limited to 6.0V output. Quote:
My servo is rated for 7.2V, so I run it straight off my 2S LiPo with possibly some reduced life span down the road. But the servo is too weak and needs to be replaced as soon as I can afford it anyway... | ||
