Thread: Do you think an XL-5 or EVX-2 will run three 380 motors?
Old 04-11-2011, 12:46 PM   #1
Nobody
Cordwood's Avatar
Default Do you think an XL-5 or EVX-2 will run three 380 motors?
I'm trying to decide what to run for an esc in a Cliff Climber 6x6 that I'm finishing up. I've read an XL-5 will run two motors in the 30-35 turn variety, but I'm curious how it might work with three stock cliff climber 380 motors?
I have an EVX-2 as well, but I'm not sure how you'd wire it up to 3 motors since it has two sets of motor leads.
thoughts?
Cordwood is offline   Reply With Quote
Old 04-12-2011, 08:12 PM   #2
Nobody
Cordwood's Avatar
Anyone have an opinion on running an EVX-2 esc with three 380 cliff climber motors? I was considering paralleling one pair of motor leads to the front and rear axles of a 6x6, and the other pair of motor leads to the middle axle. Right now with an older rooster on 2s, motors in parallel, it won't crawl over a pillow.
This for a 6x6 build in the cliff climber forum. Check it out, there's like 1, maybe 2 people following along right now...
Old 04-12-2011, 08:25 PM   #3
with the EVX-2 you need two batterys unless you do the one batt mod, Its pretty normal for the cliff climber not being able to crawl a pillow
dezrik is offline   Reply With Quote
Old 04-13-2011, 04:22 AM   #4
Nobody
Cordwood's Avatar
I was going to do the jumper mod and run one 2s.
Yeah, I know. It was just something fun to do with a bunch of worthless CC axles laying around.
I have three old rooster esc's. I'm wondering giving each motor it's own rooster would work better than using the EVX-2 to run all three.
