04-17-2011, 10:37 PM | #1 |
Quarry Creeper Join Date: Jul 2008 Location: looking for that perfect setup
| DX3R bind
im trying to re-bind a reciver to the same remote when i put in the bind plug no light goes on nothing happens help? |
04-17-2011, 10:43 PM | #2 |
Not sure what you are doing but you have to put the bind plug in with the power off. Then plug in your battery or turn on the switch and the light on the receiver should blink quickly. Hit bind on the remote and it should work fine. If that doesnt do it give us some more information and we should be able to help. |
04-17-2011, 10:45 PM | #3 |
Rock Crawler Join Date: Jan 2010 Location: Arvada
above advice is good, if the light isn't coming on when you plug your battery in make sure your esc is plugged in right. If you do all of that and still no light then the receiver could be bad.
04-17-2011, 10:53 PM | #4 |
^i tried, no luck i have recently made changes to my crawler where i had to unplug everything from the receiver and reset the controller i put it back together (plugging everything back in the same) and i plugged followed the instructions above (bind in the bat/bind) < where i normaly plug my external bec into. the FXR lights flash quickly and there is no light from the spektrum reciver at all |
04-18-2011, 01:07 AM | #5 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Have you got any power going into the receiver? Have you got the Bec plugged into another slot, OR put the red wire of the FXR back in? If not, thats you're issue, no power to your RX... |
04-18-2011, 01:40 AM | #6 |
Rock Stacker Join Date: May 2009 Location: Wausau
i had this problem before if the esc is not progamed to the remote it will cause this issue. unplug all connections to the receiver insert bind plug and plug a battery pack into just the rx and follow the bind instructions. if this doesn't help i would get a hold of spektrum. hope this will help |
04-18-2011, 01:49 AM | #7 |
04-18-2011, 05:29 PM | #8 |
thanks for the help guys i got it to finally work after moving the plugs and re-attaching the red wire |
04-19-2011, 06:01 AM | #9 |
04-19-2011, 11:32 AM | #10 |
| Yea if you are running the BEC directly to the servo the red wire needs to be plugged in to power the receiver. If you are running the BEC through the receiver then you can pull the red wire. |
