04-25-2011, 12:39 AM | #1 |
Pebble Pounder Join Date: Jun 2004 Location: burton
| old batteries
have not touched my batteries in a few years and I go to charge them and the charger says battery volt too low. Is there any way I can revive these NIMH packs?
04-25-2011, 07:53 AM | #2 |
Your only hope is to trickle charge them at about .1 amp to see if they take a charge.
04-25-2011, 10:05 AM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
when i know i won't be using my nimh batt's i run a charge on them at a low amp trickle then run some mah's off them before they sit again....i do that bout every two months and never had any problems .........bob .... |
04-25-2011, 10:21 AM | #4 |
Sounds like your charger might be a little too smart for them batteries. Can you get a hold of, or borrow, a more low-tech charger? If you're using a charger that asks how many cells, maybe try telling the charger you'e trying to charge a smaller (# of cells) pack until it starts to get a solid charge going. All I can reccomend at this point is be patient, charge low and slow, and it'll take anywhere from a few to several cycles to get them back up.
04-25-2011, 10:33 AM | #5 | |
RCC Addict Join Date: Nov 2008 Location: J-Braaaapin It Through Gate 10
x2 I usually use my mega peak charger to charge nimh packs and my good charger for my lipo's. When I put a few of my nimh packs on my good charger they won't take a charge, It just says volt error but put it on my mega peak charger and they charge fine Hope this helps. | |
04-26-2011, 08:44 AM | #6 |
Newbie Join Date: Mar 2008 Location: Traverse City
Ya just do some slow charge in nimh mode asnd get a little voltage back into them. your charger should recognize after a short charge. Keep it below 1 amp
