04-26-2011, 10:24 AM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Rock Springs
| Dual magnet motors vs. quad magnet motors?
What are the differences between dual and quad magnet motors? Does one work better for dual escape digging?
04-26-2011, 10:47 AM | #2 |
2 magnets. Seriously, search through the "comm cuts and motor tweaks" thread, there is some good info in there... |
04-26-2011, 12:18 PM | #3 |
RCC Addict Join Date: Jun 2006 Location: hillsborough
here ya go straight from the source 4 magnet can=better low speed resolution, more overall power and RPM, little less drag brake. I torque remains about the same... 2 magnet= better drag brake, but not as good low speed resolution.....little less power and RPM. Again, its not a huge difference on the power stuff. Many people notice the low speed feel and the drag brake feel differences. |
04-26-2011, 01:21 PM | #4 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
I like 2 mag motors my self....4 mag seems to lack the drag brake I like for my driving style..but lots of guys love the 4 mag.. Seems to be all personal preference.. |
04-26-2011, 05:58 PM | #5 |
Thanks for the replies. I am about half way through the suggested tread. I currently have Team Brood 35t 4 magnet motors. I have noticed on digs the locked out motor will still slightly roll. Edit: EddieO is right they are not five pole. Also I am running duel FXR's and a 4pk. I have talked to Harley and Randy Pike about this. They keep coming back to motor holding power. Last edited by Khador12; 04-26-2011 at 07:05 PM. |
04-26-2011, 06:17 PM | #6 |
I wanna be Dave Join Date: Apr 2007 Location: Arlington, Washington
5 pole? From me? I've never sold a pair of 5 poles.... Later EddieO |
04-27-2011, 07:07 AM | #7 |
Really? I run 4 mag Broods with Mamba Micro Pros and I can get them to lock up nicely. Do you maintain the motors well?? Is your mesh fine? |
04-27-2011, 09:38 AM | #8 |
They have been that way from new. Yes, I do believe in motor care. After reading the forum you suggested, I decided it was time to get a comm. lathe again. Man I forgot all the stuff that can be done to brushed motors.
04-27-2011, 09:39 AM | #9 |
tighten your rear pinion mesh
04-27-2011, 09:46 AM | #10 |
04-27-2011, 10:41 AM | #11 |
Ah, you had me worried there you brain washed me into sending 5 segment arms....I just baked some up last night though 4 magnets will sometimes have that roll feel to them. I am not sure why some notice it more than others. Mine don't seem to do it. I would make sure you are keeping the brushes a solid length, as a shorter brush decreases spring tension, which can reduce holding power. You may try a stiffer spring. Depending what era motor you have, they are either trinity purples or sagami silvers. You can try a Trinity Silver or even a black to see if that helps your drag brake. Later EddieO |
04-27-2011, 12:50 PM | #12 |
I will give the gear mesh a try. I will also be getting some springs.
