04-27-2011, 03:06 PM | #1 |
Rock Stacker Join Date: Apr 2007 Location: Seattle
| Camping... How to charge the batteries?
My wife and I are planning a week long trip to Glacier Natl. Park this summer, and I'm definitely wanting to bring my rigs. What kind of setups do you use for charging away from home? I have a couple of different batteries for my rigs, here they are: MRC - 730mah 2s, 730mah 3s, 850mah 3s SCX - 3500mah 3s Slash4x4 - 5000mah 3s I use a Turnigy Accucel 6 charger at home, and it is DC only (i run it off a PC power supply). Can this be run right off the car battery? How much charging do you think it can do before it drains the battery? |
04-27-2011, 03:11 PM | #2 |
Rock Crawler Join Date: Jun 2010 Location: Yelm,WA
I think most chargers have alligator clips that you can plug onto your car battery |
04-27-2011, 03:21 PM | #3 |
Rock Crawler Join Date: May 2009 Location: 354
this is the exact charger I got and yes you can just go direct to your car battery works great. I do bring a booster with me at all times, just incase I drain the car battery out. i've charge 2, 2200 mah 3s with no problems, truck starts right up. Last edited by ped453; 04-27-2011 at 03:24 PM. |
04-27-2011, 03:27 PM | #4 |
RCC Addict Join Date: Dec 2009 Location: Rock Bouncin' with the Patented Technique
I just use my dads truck battery for all my battery's. (5000mah 3s's) I usually crank the truck up and let it run for a little while around 2500-3000mah
04-27-2011, 03:28 PM | #5 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
I'd try it out at home and see how much charging you can do before you drain your car battery too much. |
04-27-2011, 03:35 PM | #6 |
Pebble Pounder Join Date: Oct 2010 Location: In the dog house
Sign up for harbor freight adds and you can find this for around $90. http://www.harborfreight.com/engines...tor-66619.html |
04-27-2011, 03:39 PM | #7 |
a car battery is rated at 40-140 Ah or amp hours your slash battery is 5000 Mili amp hours lets say you had a car battery rated at 120 Ah thats 120,000 Mah so you could theoreticly charge your slash battery 24 times before the car battery was completely drained. just start the car every 2-3 packs and youll be fine. |
04-27-2011, 03:43 PM | #8 | |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
04-27-2011, 04:12 PM | #9 |
Quarry Creeper Join Date: May 2009 Location: melbourne/palm bay
take a spare motor with a servo arm attatched to it......wire it to the battery charger and crank the poop out of it.....instant generator |
04-27-2011, 04:16 PM | #10 |
Another option is a "jump pack". I have a craftsman unit that I use. It has a power inverter, air compressor, and work light built in. I haven't tested it to see how many charges I can get out of it though. Another option is picking up a used car battery or even a new one...charge it up and charge away!
04-27-2011, 04:18 PM | #11 |
| not why he said before it is completely drained or anything...... |
04-27-2011, 04:26 PM | #12 |
Rock Stacker Join Date: Jan 2011 Location: Sundre, Alberta
I have a generator that I use to charge my trailer, so pretty much everyday I charge my trailer and my batteries
04-27-2011, 05:48 PM | #13 |
Thanks for the insight guys. I was mostly sure I could just use the charger straight off the car battery, but the reassurance is always good. We are tent campers, so I don't have a generator as an option. Anybody tried charging while the vehicle is driving? How much amperage does a charger draw? Too much for a cig lighter? |
04-27-2011, 05:58 PM | #14 | |
RcBros Hobbies Join Date: Nov 2005 Location: Oregon
I purchased a decent sized power inveter (ok its overkill, much smaller will do) and installed it underneath my back seats in my truck. It is then wired to my trucks battery along with what we call a power timer. I have the power timer set at 4 hours. This way if I forgot about it, the power is killed after 4 hours or use. If I need it on longer then that, just cycle the ignition, and another 4 hours starts. I can charge batteries while driving and there still within reach. | |
04-27-2011, 06:36 PM | #15 |
| Automotive batteries are considered dead @ 10v. Their usability is also negligible at half of their rated capacity (when voltage does down, amp draw goes up). When you figure the load and the amp capacity needed, you double it. There is a formula for that, but I can't think of it right now...something like amps x hours x 2.
04-27-2011, 06:40 PM | #16 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
04-27-2011, 06:47 PM | #17 |
not a lipo charger, but back when running nitros every weekend we would have 4 quick chargers (for 6 of us) all ways quick charging up ni-cd for our starter, soso so we probably charged 12-20 batteries a day off a single truck battery, and then went home...so i'm sure if you charge 3-5 batteries then start your car up and let it run awhile you'll be fine.
