05-07-2011, 11:01 AM | #1 |
RCC Addict Join Date: Mar 2010 Location: Colorado Springs, Co
| DX6i Auto Center 5 min mod
So I just converted to twin stick driving. This is how I've got my auto center modded for the time being till I can find all the parts I need to make it happen. Take a piece of .030 lexan, cut it into a strip about 1/2 inch wide and about 4 inches long. On the top and bottom for the lever there's two hole that you can perfectly thread a 2x12mm screw into. The tighter you screw it in the more resistance and faster centering you get from the flex of the lexan. works just as good as a spring. Make sure the lexan sits flat across the lever so that it's centered then adjust each screw for precision. Extended up. |
05-07-2011, 02:03 PM | #2 |
Nice "cheap" idea Adam. You settled into CS yet?? We miss you @ comps for GSRCRC. |
05-07-2011, 04:29 PM | #3 |
Quarry Creeper Join Date: Mar 2011 Location: Universal City, TX
I don't understand wht you are doing here. And what vehicle is that? What are the benefits of 'twin stick driving' and 6 channels on a crawer? Just curious. I am still rocking the 2-channel pistol that came with my Dingo. -- Sent from my Palm Pre using Forums |
05-07-2011, 04:58 PM | #4 | |
05-07-2011, 05:00 PM | #5 |
| I'm mostly settled here now. Still have some unpacking to do but I've been crawling for sanity's sake I miss comoing with GSRC too, but there's a great bunch of guise and gals that comp over here, and some killer comp spots too.
06-08-2011, 07:01 PM | #6 |
Quarry Creeper Join Date: Aug 2007 Location: Rocklin, CA
| Sweet idea. Works like a charm. Thanks for sharing.
06-08-2011, 10:33 PM | #7 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
Trick idea, that is a lot easier than springs! Thanks for the TIP, should help me finish my 2nd trigger quicker than dealing with installing springs |
06-09-2011, 12:19 AM | #8 |
Newbie Join Date: Sep 2009 Location: Australia
I'm also using a dx6i for my xr10. sooooo much better than the pistol grip (once you get used to it). I have set both motors to run together at the same speed on the left stick only (elevator) but can be overun by the right stick (front motor). Then I can also flick the D/R elevator switch and have total independant control of both motors on the two sticks. Flick the switch back and your back to one left stick for both motors and right stick for steering (left and right) To get the self centering on the right stick I simply unscrewed the four screws and rotated the stick from the inside 90 degrees to give forward and backward self centering. Hope that makes sence. |
