05-10-2011, 12:29 AM | #1 |
RCC Addict Join Date: Oct 2007 Location: gervais
| Red wire missing?
So I just got a teken fxr and notice the wires, that go to the receiver, the red wire us missing, I searched using fxr and wiring but couldn't find an answer as to why, do any of you guys know?
05-10-2011, 12:40 AM | #2 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
When you use an external BEC the red wire needs to be pulled from the lead. Is it gone entirely from the ESC or just cut/removed at the end? If it's gone you won't be able to tune your FX-R with the Hot Wire unless you re-solder one in. |
05-10-2011, 12:53 AM | #3 |
It's just cut short, with shrink tubing closing it, got it from twisted bender so I don't know what the setting is or how to program with the hot wire
05-10-2011, 01:21 AM | #4 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
u will have to solder another in place if u wanna change the settings with a hotwire or else u cant change the settings
05-10-2011, 07:01 AM | #5 |
This is the reason that I use a short (3in) aileron extension between the ESC and RX, I remove the positive wire from the extension. That way I isolate the ESC and still can use the hotwire without having to pull and replace the pin each time.
05-10-2011, 07:12 AM | #6 |
| That is a damn good idea!!!!! Well it looks like I have to fix this then
