05-15-2011, 12:51 AM | #1 |
Rock Stacker Join Date: Apr 2010 Location: wrightwood
| What battery to run? HELP!
okay soi have a axial ax10 that i modded the suspension and moved the electronics around to lower the COG.the battery i gotwith itis ridiculous and makes the rig top heavy. I want the smallest battery i can get that will power this rig good and last as long as i can get it to last. My electronis are a integy motor with a tazer 12t esc. im not exactly sure what turn my motor is but can check tomorrw. Let me know what you guysthink would be the best or what you recommend. Thanks! |
05-15-2011, 02:53 AM | #2 |
Quarry Creeper Join Date: Feb 2011 Location: Vancouver, WA
What battery are you currently using? Where do you want to move your battery? On the AX-10 many people run their batteries either on the front axle or a tray mounted on the top links. If you want to run a lipo battery (highly recommended) you are going to be limited by space. Figure out where you want to put your battery and make a few measurements, then go shopping. Here are some places to buy batteries: www.cheapbatterypacks.com (lipo and NiMH) www.valuehobby.com www.hobbypartz.com www.hobbyking.com |
05-15-2011, 05:27 AM | #3 |
Also knowing if this is a fun rig or comp rig as well helps us help you. Do you have a LiPO capable charger? How much run time/pack are you looking for? How heavy is your rig? A 3S LiPO for a comp rig may be ~800 - 1000MAH. |
05-15-2011, 04:10 PM | #4 | ||
I was looking at a battery like this...http://www.cheapbatterypacks.com/pro...V-2S-pack.aspx. i like the compact design of it. Quote:
Currently im using a 3300 maH 7.4v ni-mH battery. I definately want to go to lipo power. I havent quite decided exactly where i will mount the battery but it will be a tight fit im sure. Thanks for the websites! | ||
05-15-2011, 04:28 PM | #5 |
RCC Addict Join Date: Sep 2006 Location: Depew
I fully support CheapBatteryPacks!
05-15-2011, 05:53 PM | #6 |
05-16-2011, 12:47 AM | #7 |
Rock Stacker Join Date: Mar 2008 Location: honolulu
Sky lipos from hobby partz! |
