05-29-2011, 12:41 PM | #1 |
Newbie Join Date: Oct 2010 Location: earth
| More servo travel ?
AX-10 running a cc 10 amp Bec, spectrum dx-3 radio, Savox digital coreless servo (Ill get the model # in a min). Id like a little more servo throw..EPA's are maxxed on the TX .Will the hitec programmer work on a savox servo ?? Or does savox have one that i cant seem to find ? I only need a few more degrees of throw from the servo.. Any help would be great, Thx P.S. I tried searching and only found the hitec programer |
05-29-2011, 02:15 PM | #2 |
I have no clue on a Savox programmer, "easy" way is to lengthen the servo arm to gain more movement. Keep in mind when you do that you drop the torque available. If you lengthen by 30%, you lose ~30% torque. |
