04-29-2006, 01:41 AM | #1 |
Quarry Creeper Join Date: Jan 2005 Location: UK
| Reverse timing on a Lathe motor
Im just thinking out loud here as to make sure I dont mess up. I have two 55t lathe motors that im gonna stick in the clod axles. With regards to the reverse timing needed for the rear motor, can I just solder the + from the esc to the - on the motor and the same for the - from the esc to the + on the motor for reverse rotation. Then, would I have with the - on the rear motor to the + to the front motor to get correct rotation for the front motor. I hope this makes sense, FLAME me if it doesnt:? |
04-29-2006, 07:25 AM | #2 |
As long as you've got zero timing, do what you like. At zero, the motor doesn't care. Only when you have advanced timing is reverse-wiring a bad thing. Since the lathe motors are adjustable, set the timing to zero and have at it.
04-29-2006, 07:34 AM | #3 |
Thanks mate, thats just waht I needed to know |
