05-01-2006, 07:49 AM | #1 |
Newbie Join Date: Apr 2006 Location: valencia
| glitching only when crawling!
ok heres one for all you experts! my crawler runs perfectly fine on the flat as soon as i start to crawl over something it starts humping it like a horny chiuawa , it's like as soon as there is stress on the motors it starts glitching, and then if im on the flat just messing around doing some s turns it will all of a sudden start crab walking whats up? setup: airtronics reciever moped esc reversed y harness hitec 645s front and rear sanyo 3000mh 6 sub c pack 2 integy 55t motors w/3 caps per motor 9t pinions and yes i did search but nobody seems to have had this type of problem. please help:? |
05-01-2006, 08:24 AM | #2 |
Do you have another esc to try? Is your antennae extended and not touching itself?
05-01-2006, 08:28 AM | #3 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
moped esc & hitec 645s front and rear Have you tried a receiver pack to see if the glitching goes away? Seems like a lot of drain on the moped with both servos always running while turning. Last edited by Unholy; 05-01-2006 at 08:41 AM. |
05-01-2006, 08:39 AM | #4 | |
the antenna is in zig zag config on plastic, the antenna does not crossover itself or does not touch any metal. | |
05-01-2006, 08:41 AM | #5 | |
05-01-2006, 08:43 AM | #6 |
If it works you can always tap out of your 6 cell pack at the 5th cell to run receiver power straight from the main battery. Saves alot of room, all it adds is a wire.
05-01-2006, 08:50 AM | #7 | |
